Construction Tips Construction techniques and tips
Drilling aluminum
Drilling aluminum
Old 31st December 2017, 06:58 PM   #11
lcsaszar is offline lcsaszar  Hungary
Originally Posted by globalplayer View Post
Maybe high rpm and low force.
Just the opposite: low revolution, but a super sharp (new) HSS drill bit. And some oil, as it has been suggested. I usually go in 0.5 mm steps.
Old 31st December 2017, 07:29 PM   #12
Trollet is offline Trollet  Sweden
Trollet's Avatar
Drilling aluminum
I've drilled hundreds of holes by free hand, and of corse some moore with different machines.
Make a good marking for a start. Pre drill with about 3.5 mm It's a good choice working on free hand so it won't break.
Start slow and increase speed to when you'll see that it cuts nice.
Some lubricant may do good but isn't necessary. WD 40 or something will work.
Remember that it's the preparing before drilling that gives good precision.
Figge
Old 31st December 2017, 07:37 PM   #13
jwilhelm is offline jwilhelm  Canada
The question was about enlarging a 6mm hole to 1/4" which would work out to removing about 0.016" of material. That's a lot harder than just drilling a fresh hole as there isn't enough material present for the relief angles on the drill bit to control anything.
https://www.vzaudio.com/
Old 31st December 2017, 09:52 PM   #14
Elvee is offline Elvee  Belgium
Elvee's Avatar
Originally Posted by jwilhelm View Post
You will likely have the best luck reaming the hole to size. Trying to drill that small amount of material usually ends badly because the drill bit will just grab. SOWA - Homepage
Yes, a normal drill bit without the help of a drill press will almost certainly grab, but reamers aren't well suited to blind holes either.
What I sometimes do in similar circumstances (not these exact ones, since I have a drill press) is to modify a drill bit: essentially reducing the cutting angles in this case. It is relatively easy to do, even with a hand-held grinder and no guide or jig, but ideally you would need to make a test before any attempt on the real part: even a moderately thick aluminum plate would be sufficient for that.
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 31st December 2017, 10:50 PM   #15
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
Drilling aluminum
What's the shaft made out of? If aluminium, could you sand it down a touch? wrap some maybe 240 grit wet and dry around it and turn it round and round. May not be practical.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 31st December 2017, 10:53 PM   #16
wanders is offline wanders  United States
Shaft look like stainless.
Old 31st December 2017, 10:54 PM   #17
just another
wintermute's Avatar
Drilling aluminum
OK that's out then!!
Some of my photos
Old 31st December 2017, 10:55 PM   #18
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
I've filed a 1/4in steel shaft and fitted 6mm knob
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 31st December 2017, 11:12 PM   #19
martyh is offline martyh  United States
I would just chuck a sharp 1/4" drill bit into a tap wrench and turn it in by hand.
Old 1st January 2018, 12:08 AM   #20
Thst’s a good idea!
Drilling aluminumHide this!Advertise here!
Advice on finishing raw aluminum.. keeping the aluminum look thehoj Construction Tips 30 29th August 2015 04:58 PM
TO-3 Drilling Jig BrianDonegan Solid State 17 11th January 2014 04:33 PM
Drilling aluminum mantisory Everything Else 53 21st November 2007 05:19 PM
drilling/tapping aluminum elizard Parts 32 6th March 2004 06:18 AM
