Construction Tips Construction techniques and tips
Which end of the power cord should the braided shield be grounded to?
Old 15th November 2017, 12:06 AM   #21
MAAC0 is offline MAAC0  Portugal
I'm pretty sure your in-wall wires are shielded by bricks or concrete and The wires that come from the power station are shielded by air or earth if buried. Do You believe in Santa Claus ? I not.
Old 15th November 2017, 05:19 PM   #22
Speedskater is offline Speedskater  United States
Speedskater's Avatar
Shield in this case is about blocking electrical signals in the air. Not about insulation or mechanical protection.
Almost all shields are metallic like copper, steel or aluminum. Different metals and shield construction work better at different interference frequencies.
Kevin
Which end of the power cord should the braided shield be grounded to?Hide this!Advertise here!
Advantages of Power Cords with braided Shield for high Power Solid State Power Amps tiefbassuebertr Solid State 57 27th July 2015 04:56 PM
Does a metal/conductive enclosure need to be grounded in order to shield? 454Casull Solid State 15 26th October 2011 11:39 PM
dialectics and shield of an umbilical cord? phrarod Analog Line Level 8 10th July 2010 11:40 PM
Any issues with adding a grounded power cord to a Heathkit IT-17 tube tester? BoilermakerFan Equipment & Tools 2 27th June 2010 08:34 PM
Grounded power supply cord on a transformerless amp ? bereanbill Tubes / Valves 5 8th June 2009 12:11 AM
