Construction Tips Construction techniques and tips
Frugel Horn veneering advice needed
Old 22nd October 2017, 02:05 AM   #1
dougjh is offline dougjh  United States
Default Frugel Horn veneering advice needed
Hello,
I am looking for some suggestions on how the Frugal Horn design should be veneered. Specifically wondering if the side panels and back panel should be veneered prior to assembly. I am not certain how one would veneer the back and inside of the panels after glue up.
Thanks!
Old 26th October 2017, 10:54 PM   #2
chrisb is offline chrisb
Having built a few of these, I'll describe my practice.
I use only close to architectural grade maple faced BB plywood, so the back panel and inside of mouth on both side panels can be clear coated or painted before assembly - at least with a seal coat. If using MDF or particle board (which I personally avoid except for jigs), then yes, you'd want to pre-veneer those parts first. If that's the case, you'll need almost double the amount of veneer to complete the pair, and I wouldn't want to rely on butt joints of lateral panels to the sides - I'd screw from the outside, and fill, then post veneer after case fully assembled.
If sides and back panels are prefinished, when gluing up, wipe off any visible seepage with a wet then dry rag after clamps are set. The second side is a bit trickier, as there's not a lot of room (140mm /5.5" in the case of the FH3).
Due to the curved side panels, the yield isn't great. I happen to like to align any figuring to follow the 5dg tilt of the front panel, as well as to wrap the pattern contiguously around the enclosure, mirror image the two cabinets, and center the figuring on front panels. As the flitches on book or slip-matched veneer can vary in width from sheet to sheet, this layout can take some time, and I've always had to dedicate a full 4x8 sheet per pair for either the FH3 or XLs. Most of the engineered / reconstituted veneers I've used have a much tighter grain or pattern figuring -close to rift / quarter cut, so the waste is slightly lower.
I assume you don't need any instruction / advice on the actual veneering part, but I use the iron-on yellow glue method.
kinda burnt out - taking a break
Old 27th October 2017, 01:11 AM   #3
Thank you for your advice. It is exactly what I was looking for.
Doug
Old 31st October 2017, 04:56 PM   #4
Doug - if not too late a few photos of veneering of FH3 from one of the few times I slow down enough to pick up the camera. As is clear, the curved side panels through a monkey wrench into efficient break out, but I've found this layout works pretty well for a wide range of grain figuring.
Note that I don't worry about scorching with the iron - in fact with some practice, the nose of the iron can be helpful in starting the trimming out of rebated openings for drivers such as Alpairs.
This pair went to Cal Weldon - veneer was flat sliced red oak, with Watco Fruitwood stain and satin finishing wax, and the rear mouth openings sprayed with textured paint and varathane clear top coat. Those are waterborne products that take a few light coats and lots of drying time to fully cure.
Old 1st November 2017, 12:21 AM   #5
Thanks Chris! No, not too late. I have the bb plywood and the sapele veneer. And I have two choices in hand for the drivers, a pair of Alpair 7.3's and a pair of Fostex FE126En's. The only thing I haven't yet got in the bag is the WAF... Still working that one.
Doug
Old 1st November 2017, 12:48 AM   #6
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
FE126En will play louder with less power, but really need a corner to get best bass out of them. Except for the efficiency the Alpair is the better choice.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 1st November 2017, 06:05 PM   #7
Doug - +1 to Dave's sentiment. If you have sufficient power, the Alpair would be my recommendation. Baffles take a bit more time than with the Fostex, as the Alpair's thick bezel requires rebating for flush mounting, and chamfering of rear side of driver hole needs to be scalloped around the 4 screw mounting locations.
The sapele should look gorgeous - if you have the option, I'd go for the copper / gold colored Alpair cones.
Frugel Horn veneering advice neededHide this!Advertise here!
Advice needed: 3-way Horn speaker build. sxam Multi-Way 4 1st August 2017 04:35 PM
Frugel-Horn Mk3 single driver horn speakers Rabco Swap Meet 3 29th May 2017 08:17 PM
Advice about veneering a speaker cabinet vintageaxeman Full Range 17 26th November 2015 08:30 PM
Gamma Horn loaded Ribbon VLD-13 - Application Advice Needed icefox Multi-Way 32 30th September 2012 10:58 AM
Adire Koda 8 tapped horn , advice needed 316a Subwoofers 7 17th June 2010 04:12 AM
