Construction Tips Construction techniques and tips
Russ Andrews "Minizaps"
Old 19th October 2017, 07:55 PM   #11
Britain4 is offline Britain4
Originally Posted by Mooly View Post
The Pioneer A400 uses a 'passive preamp' and so each record output switch simply places that tape output in parallel with the selected source.
There is a 2k series feed to each output.
So if you select record output 1 and 2 to be both CD, then both outputs are placed in parallel with the CD input sockets.
If you load the record outputs in any way, that load appears as a load across the selected source (CD in our example).
If you set the record selector to OFF then all output feeds are grounded and disconnected from the inputs.
That is the best option. Set to OFF. Job done.
I missed this earlier, apologies for not acknowledging it sooner. I did figure that out earlier with a glance at the schematic and a prod round with a multimeter but thank you for confirming it
My RCA plugs arrived today, made them into shorting plugs and I can no longer hear my CD player from any other source, nothing but dead silence, so I really do think they’ve helped with noise! But as advised, I won’t be putting anything on the outputs. Thanks all
Russ Andrews "Minizaps"Hide this!Advertise here!
Russ Andrews "Zapperator" circuit Britain4 Construction Tips 25 23rd October 2017 03:40 PM
Russ andrews dac 1 vs Headroom Portable Desktop amp goodguys Digital Line Level 1 12th October 2013 04:01 AM
F/S Russ Andrews Kimber 8TC Jumper Cables Mr Onion Swap Meet 1 7th September 2012 08:01 PM
Russ Andrews - Crossover Upgrade ringo_the_hifi Multi-Way 8 19th July 2009 11:30 AM
Russ Andrews voltage reg stoolpigeon Solid State 10 8th July 2007 11:04 AM
