Construction Tips Construction techniques and tips
My first stereo PA
My first stereo PA
Old 11th November 2017, 09:54 AM   #11
Elerion is offline Elerion  Spain
Finished!
The amp sounds wonderful. Clean, and no hum or noise whatsoever.
I painted after making drills, but before mounting components.
After several weeks, the paint is still in place. There're a few little scrathches, probably made while mounting things and working on the soldering, exposing a very tiny area (less than 1 mm size) of aluminium (or primer). It could be painted again with a fine brush.
Definitely not perfect. It has to be treated with some care. But the paint procedure I used seems like a reasonable alternative to more complex or expensive ones.
My next project is going to be using a steel chassis, though. Never worked neither painted steel before. I expect a much harder to work material (drilling is not of concern to me, but cutting definitely is) and easier to paint.
Old 14th November 2017, 07:34 PM   #12
chrisb is offline chrisb
Yes, compared to Aluminum, steel will be a bitch to fabricate by hand. Any commercial powder coaters nearby? For either material, I've found the extra few bucks over the raw cost of material for aerosol paint products is easily justified by the reduced prep time, and durability of finish. The local shop I use pre-washes to remove any residues that could impede adhesion, and they have a great range of stock colors and textures.
like my mind, this space intentionally blank
My first stereo PAHide this!Advertise here!
Mauro Penasa MyRef Rev C 3886 Stereo Amplifier with TDA7294 Stereo Woofer Amp VictoriaGuy Swap Meet 8 6th February 2017 10:16 PM
HELP needed - LEAK Varislope 2 Stereo + Stereo 20 with pictures... triole1 Tubes / Valves 13 28th March 2014 06:55 AM
My stereo amplifiers produce mono output with stereo source! tsiros Solid State 2 3rd November 2013 07:17 AM
Looking to make a mono sub from a stereo output while keeping stereo speakers. JForged Multi-Way 17 14th December 2012 01:37 AM
sony SVO-1630 hi-fi stereo vhs stereo recording/playback problem neazoi Analogue Source 1 7th October 2011 07:36 AM
