Construction Tips Construction techniques and tips
Using cable grommets for mains leads? Still legal?
Old 20th October 2017, 06:28 PM   #11
chrisb is offline chrisb
For fixed connections with lighter gauge power cable, there's always the Heyco strain relief grommets. Being nylon, they're not susceptible to the same degradation as rubber, but they still also need a non circular panel opening . Strain Relief Bushings | Power Cord Strain
I think they were pretty much a standard in mainstream consumer electronics for decades, until the advent of the IEC.
There's a helluva range of sizes and shapes of IEC receptacles, my favorite is probably the small one with integral fuse holder - some models with switches are huge, and if cutting openings by hand can take a fair bit of time, particularly in steel panels.
like my mind, this space intentionally blank
Old 21st October 2017, 12:05 AM   #12
phase is offline phase  United States
This is what I just used on a 35 year old amp to replace the dried up lamp cord with 12-3 on an amp.
1497 Heyco | Mouser
Had to enlarge the hole in the case to .875 Dia.
Old 23rd October 2017, 09:10 PM   #13
VenusFly is offline VenusFly  Australia
VenusFly's Avatar
I went down to bunnings today and got myself some star washers and some M5 screws and bolts and some eyelets and some AU plugs and some fine files. Also got some Sutton tools Viper drill bits, 1mm-10mm with no gaps in the sizes.
I also ordered some stainless steel PG7 4-6mm waterproof cable grommets:
6 Pcs PG7 Metal Waterproof Locknut Stuffing Cable Gland Connector | eBay
Also ordered a step drill a week ago.
A freeman. Love your neighbours and Love nature. Stop cutting down trees to make houses a stones throw from your neighbour and join your real home, the rainforest.
Old 23rd October 2017, 10:35 PM   #14
1497 Heyco | Mouser
Almost exactly the part I can remember as part of the Hafler kits of which I built literally hundreds for a local hifi shop back in the mid 70s- early 80's - even the 500 used them . Now, unlike the small preamps, that was not a product you'd want to drag around by the power cord. While 45lbs might not seen overkill in today's market, it was still a brute to build.
Old 24th October 2017, 01:26 PM   #15
Speedskater is offline Speedskater  United States
Speedskater's Avatar
I just posted this in the wrong thread:
On the power cord entry thing, do a search for:
power cord strain relief bushing
The ones that fold over on themselves should work.
I was in the hardware store and they had a box of assorted models
Kevin
Old 24th October 2017, 08:31 PM   #16
Kevin - I think you're talking about the same thing as the Heycos noted above.
Using cable grommets for mains leads? Still legal?Hide this!Advertise here!
DIY Mains Cable advise please Stewart Holmes Parts 16 18th February 2014 10:06 PM
Mains Cables R Us No.91 Mains Lead with Belden 83803 Cable mainscablesrus Mains Cables R Us 2 17th April 2012 09:11 PM
Suspension Grommets JonesS Analogue Source 2 17th November 2005 01:20 AM
DIY Mains Cable Blue_Max Everything Else 0 15th May 2004 12:24 AM
Replace the Mains cable Ryssen Solid State 3 18th January 2004 07:59 PM
