Construction Tips Construction techniques and tips
Steel sheet refinish
Old 18th October 2017, 02:32 AM   #21
jfetter is offline jfetter  United States
jfetter's Avatar
3M Automotive product:
http://multimedia.3m.com/mws/media/5...%20Etching.pdf
I see the dental product you mentioned, not familiar with it.
“A grounded grid is a happy grid”. jfetter
Old 18th October 2017, 03:56 AM   #22
Dave Zan is offline Dave Zan  Australia
Thank you, I have never seen this product, probably not distributed in Australia.
Rustoleum brand is available but I think I will stick with polyurethane.
I have a more-or-less acceptable surface texture now, will try garnet abrasive in my sandblaster and hope to improve it.
Best wishes
David
Old 1st November 2017, 11:28 AM   #23
HYPERTUNE is offline HYPERTUNE  Australia
Originally Posted by Dave Zan View Post
I plan to use polyurethane primer, it's an area flooded by coolant and the industry recommendation is to use a polyurethane paint.
Metalworking machine? Depending on the coolant it might be worth using 2 part epoxy.
Old 1st November 2017, 10:58 PM   #24
Originally Posted by HYPERTUNE View Post
Metalwork...?....2 part epoxy.
Yes, it's the coolant tray and cabinet stand for a metalwork band-saw.
A 2 pack epoxy primer would probably be a little better but it's a pain to mix, and to have limited pot life.
I have done the full 2 pack epoxy + polyurethane topcoat in the past but for this small job it's just not worth it, plus the expense to buy paint when I only need a fraction of a can.
However, I did learn recently that there are now 2 pack spray cans, where some internal separator is broken before use.
Saves some of the fuss but fairly expensive, the POR-15 is already not cheap.
Best wishes
David
Steel sheet refinishHide this!Advertise here!
Refinish cabs? MJClemm Swap Meet 0 11th January 2012 05:25 AM
PPI seonda amp refinish job IrishboyM4 Car Audio 30 22nd November 2008 09:34 AM
Steel as a heatsink? spooney Car Audio 11 28th December 2007 04:02 AM
Need opinions, refinish or leave alone. Cal Weldon Multi-Way 8 24th July 2007 08:28 AM
Steel cabinets? bfg9k Multi-Way 1 5th January 2004 03:35 AM
