Construction Tips Construction techniques and tips
Build a high-end CAT cable
Old 20th July 2017, 01:03 PM   #21
Speedskater is offline Speedskater  United States
Speedskater's Avatar
Audioquest cable and high quality Cat cable is an oxymoron. For high quality Cat5 and up cable go to Belden.
Kevin
Old 24th January 2018, 08:01 PM   #22
wlowes is offline wlowes  Canada
wlowes's Avatar
Originally Posted by Tromperie View Post
Use Cat7 cable;
Cat7 - Wikipedia
Plus 1 on that one.
Saw some banter on another site claiming Cat7 improves sound connecting NAS / router / music server. Makes no sense.
Bought cheapest Cat7 from Amazon and replaced my old Cat5. For me, a clear sound improvement. I refuse to speculate why, discuss merits of double blind test or why my ears are lying. I agree with all of it. If curious, spring for $10 and try it. If offended, I apologise... assume I am nuts.
Old 25th January 2018, 08:31 PM   #23
DF96 is offline DF96  England
Probably the old Cat5 connectors were dirty. Simply unplugging and putting back may have cleared the dirt.
Old 25th January 2018, 09:14 PM   #24
Yep. there was some sort of problem with that old Cat5 cable.
Kevin
Old 27th January 2018, 08:34 PM   #25
wlowes's Avatar
Perhaps that it wasn't a Cat7
I have used several different Cat5 that were in the old cable box. Worked fine in their original network cable application at the office. The new Cat7 ones were better for making sound happen at home. I wonder if the new level of shielding keeps some level of interference out of the system that degrades the sound?
At any rate, I realize this is off topic. The OP just wanted to know how to build his own cables. I agree with other comments that getting the spec correct would make this a challenging build and suggest you try Cat7 before going to a bunch of expense. If you do build your own with good outcome that exceed Cat7, then definitely share your experience and build experience.
Old 29th January 2018, 12:44 PM   #26
Cat7 for digital audio? Oh dear.
Try some Cat3, it should work just fine.
Kevin
Old 7th February 2018, 06:19 PM   #27
ltusler is offline ltusler  United States
Now there is a Cat 8 standard out.
"Category 8 cabling infrastructure has been designed to support short-distance (between 5 and 30 meters) runs of 25- or 40-Gbit/sec transmission."
That should support your Ethernet connection.
Build a high-end CAT cableHide this!Advertise here!
High end instruments cable azerty254 Parts 0 17th July 2011 06:12 PM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 07:54 AM
High end digital cable MichaelJHuman Everything Else 1 30th August 2005 02:41 AM
Cheap powerstrip, DIY high-end cable w00t Parts 11 19th February 2004 03:48 PM
