Construction Tips Construction techniques and tips
Build a high-end CAT cable
Old 17th July 2017, 10:25 PM   #11
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Telephone exchange, where the interweb comes from
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 17th July 2017, 10:29 PM   #12
chrisb is offline chrisb
7500 GPB for a 12meter, directional network cable? well, at least they offer financing - or maybe accept organ donations?
we're in the wrong frickin business, I'd say
Old 17th July 2017, 10:29 PM   #13
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
I see. Today you've overdone yourself. Congrats.
Old 17th July 2017, 10:34 PM   #14
My very serious point is that I get high enough data speed for the highest quality audio available through a couple of twisted aluminium wires a mile long, or am I missing something?
Old 17th July 2017, 10:46 PM   #15
Tromperie is offline Tromperie  Australia
Like this? AudioQuest Diamond RJ/E Ethernet Cable 12m - By Brand - AudioVisual Online - UK Home Cinema and Hifi Specialists
Have you seen the stuff they use between you and the exchange?
From the website, audiophile foolishness of the highest order
Directionality
All audio cables are directional. The correct direction is determined by listening to every batch of metal conductors used in every AudioQuest audio cable. Arrows are clearly marked on the connectors to ensure superior sound quality. For best results have the arrow pointing in the direction of the flow of music. For example, NAS to Router, Router to Network Player.
lol, they "listen" to the cables to determine directionality. I've read some cr@p before but this takes the cake.
Source: Daphile on old PC from the tip * Storage NAS: FreeNAS 11 * Pre-amp: DIY PGA2310 * Amps: 8 x LM3886TF
Xover: 24dB @ 300 and 3,000Hz * Speakers: DIY design CNC cut 54 laminations * Drivers SB 10", SB 5", VIFA 1" VTG
Old 17th July 2017, 10:47 PM   #16
Use Cat7 cable;
Cat7 - Wikipedia
Old 17th July 2017, 10:48 PM   #17
analog_sa's Avatar
What's speed got to do with perceived sound quality?
What about radiated noise?
Perhaps there other factors too. Difference between ehternet cables is so startling i seriously consider going back to wifi.
Old 17th July 2017, 10:54 PM   #18
Yeah, forget expensive wires, send it through the air....
Old 18th July 2017, 12:22 AM   #19
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Your connection to the internet will be governed by the connection to the change, but a network cable is intended to give local network performance. It wonít be the bottleneck to the internet, but it can degrade local performance. Speed is useful for data transfer (including remote access to the machines downstairs).
Here the telco usually runs optical fibre to the house, the cable company brings it in by sheilded co-ax from a local head-end which is connected via fibre. The cable company is easier to deal with and we get (at least the plan iím subscribed to) 20 Mbps download and 1/10 that for upload.
Here the use of CAT5 is for cables, and is just a source of cheap high quality copper.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 18th July 2017, 09:13 AM   #20
DF96 is offline DF96  England
Yes you are missing something: coding and modulation. The signals between you and the exchange are coded in a completely different way from those between your computer and the local router. Google may help you.
Build a high-end CAT cableHide this!Advertise here!
High end instruments cable azerty254 Parts 0 17th July 2011 06:12 PM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 07:54 AM
High end digital cable MichaelJHuman Everything Else 1 30th August 2005 02:41 AM
Cheap powerstrip, DIY high-end cable w00t Parts 11 19th February 2004 03:48 PM
