Construction Tips Construction techniques and tips
How to mount transistors to heat sink
Old 9th July 2017, 11:38 PM   #1
JeffYoung is offline JeffYoung  Ireland
JeffYoung's Avatar
Default How to mount transistors to heat sink
I'm planning on using Kapton tape (because I happen to already have some) for insulation.
Do I want thermal grease on both sides of the tape, or if I stick the tape to the heatsink is the adhesive on the tape enough?
Thanks,
Jeff.
Old 10th July 2017, 06:37 AM   #2
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Use mica+grease>Silpads>*proper* (ultra thin) Kapton *sheet*+grease (not adhesive tape), in that order.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 10th July 2017, 01:21 PM   #3
JeffYoung's Avatar
Thanks JM. If I can't use what I have (the Kapton tape), then I might as well order some mica.
I assume grease on both sides of the mica?
Old 10th July 2017, 01:39 PM   #4
R.I.P.
I use the glue as the air excluding medium for pre-glued hard insulators.
The unglued side needs thermal goop, again to exclude any/all air from the interface.
After a few hours of testing you will usually see that some of the glue has migrated to the edge, because it has flowed under the pressure created by the clamping. This helps to reduce the thickness of the heat insulating effect of the glue. It also helps remove any last hint of air trapped with the glue.
regards Andrew T.
Old 10th July 2017, 04:51 PM   #5
JeffYoung's Avatar
OK, this is all a bit more complicated than I thought.
Mica pads for TO-247 are hard to come by in Ireland. I can easily get Silpads and Aluminium Oxide.
The Silpads are a bit more coin, but I presume I don't need grease with them?
Thanks again for all the help.
Old 10th July 2017, 05:33 PM   #6
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
I prefer the gray silicon gum, pretty good isolation (over 500V) and good thermal transfer. Usually with grease in both sides. Also try the gray boxes that cover all the transistor, available for TO220 and TO247/TO3P.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 10th July 2017, 05:36 PM   #7
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Silpads are designed to be used on their own. May not be quite as effective heat transfer as mica and grease. Aluminium Oxide is better still but quite expensive
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 10th July 2017, 05:37 PM   #8
rayma is offline rayma  United States
Right, just clean the mating surfaces.
Old 10th July 2017, 09:45 PM   #9
JeffYoung's Avatar
Cool. Thanks everyone!
Old 17th July 2017, 03:18 PM   #10
Eric is offline Eric  United States
Eric's Avatar
It may be useful to do some 400 or 600 grit wet sanding on your heat sink to insure that the mounting surface is clean and flat. Many extruded sinks have micro ridges on the back from the manufacturing process.
My DIY Basement Theater, Aleph-X Amps, Avro Open Baffle Speakers, LDR based DCB1 + BA-3 pre, Pearl II, highly modded Technics SL-1200, F4, a40, several ACAs, FHXL, Tang Band 1772 bass-reflex
How to mount transistors to heat sinkHide this!Advertise here!
Recomend a method to mount res, to heat sink scid714 Construction Tips 9 6th January 2014 04:10 AM
Heat Sink Heat Sink Sources for Pass Amplifiers manmohan singh Pass Labs 9 16th March 2012 11:37 PM
heat sink khimh Subwoofers 1 8th December 2011 12:50 AM
PLEASE HELP! Insulating Transistors Electrically from Heat Sink Do It Yourself Construction Tips 20 4th November 2011 07:58 PM
How much heat sink is necessary? rosss Pass Labs 11 23rd February 2003 05:23 AM
