Construction Tips Construction techniques and tips
How to mount transistors to heat sink
Old 17th July 2017, 04:07 PM   #11
JeffYoung is offline JeffYoung  Ireland
JeffYoung's Avatar
Thanks for the tip, Eric. I'm using a heatsink design with a flange similar to the production FirstWatt units, so I'll make sure there's no lip on the front edge as well.
Old 17th July 2017, 06:51 PM   #12
danny_66 is offline danny_66  Belgium
danny_66's Avatar
Originally Posted by JeffYoung View Post
I can easily get Silpads and Aluminium Oxide
Best is Alumina for the DIYer.
Those silpads are more for automatic installation or when it needs to go fast and don't have the time to mess with goop
My RefSpeaker
Old 15th November 2017, 11:45 AM   #13
bhpistorqintorpm is offline bhpistorqintorpm  India
make sure you counter sink the holes on your heat sink.
also, polish the surface since extruded Aluminium surface is far from even..
finally, in my case i've made use of Copper spreader which bolted onto the heat-sink. and transistor is placed over it pressed down by Aluminium plate.
heatsink +
thermal paste+
Copper Spreader+
thermal paste+
Kapton tape+
thermal paste+
transistor
this set up has been working fine for me for past few months.
-Som
BHP=Torque X RPM : yeah i know, stuck to my automotive forum handle
Old 15th November 2017, 12:48 PM   #14
JeffYoung's Avatar
Thanks guys. Heatsinks holes are chamfered; surface is polished. I'm going to start with heatsink/goop/mica/goop/transistor and see how I get on.
Jeff.
Old 15th November 2017, 01:23 PM   #15
balerit is offline balerit  South Africa
balerit's Avatar
Plain silicone pads are fine. Here is something I do when soldering a few transistors to a pcb, using a jig:
How to mount transistors to heat sinkHide this!Advertise here!
Recomend a method to mount res, to heat sink scid714 Construction Tips 9 6th January 2014 04:10 AM
Heat Sink Heat Sink Sources for Pass Amplifiers manmohan singh Pass Labs 9 16th March 2012 11:37 PM
heat sink khimh Subwoofers 1 8th December 2011 12:50 AM
PLEASE HELP! Insulating Transistors Electrically from Heat Sink Do It Yourself Construction Tips 20 4th November 2011 07:58 PM
How much heat sink is necessary? rosss Pass Labs 11 23rd February 2003 05:23 AM
