A lesson learned!! What's yours? - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 31st October 2016, 10:55 AM   #1
pl802 is offline pl802  United Kingdom
Default A lesson learned!! What's yours?
In the process of building an amp I've been using crocodile clips in the psu section.I'd been experiencing some odd behaviour when checking actual voltages on test.I put this down to house mains variation.After all it was making sound.But last night I noticed a mini thunderstorm in the jaws of the clip lead at power on.Wish I had a recorded footage of it.Amazing to see!
On pulling back the protective covering here's what I came across.The maker didn't even bother to solder the leads.Penny pinching?
First pics are of the offending sod of a lead,the rest my repair job.
Old 31st October 2016, 02:04 PM   #2
Elvee is offline Elvee  Belgium
Elvee's Avatar
Yeah, pretty standard practice for that kind of item. You may even find that the "copper" of the wire is in fact magnetic....
Probably some advance in the quantum material physics....
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 31st October 2016, 03:50 PM   #3
DF96 is offline DF96  England
Cheap 'test leads' with croc clips on the ends are almost always badly made. Even if they are soldered you can't be sure it is a good joint.
Old 31st October 2016, 04:40 PM   #4
By the way after soldering the leads I noted an increase of 20 Vdc in my B+ supply.Interesting no.
Old 4th November 2016, 04:07 AM   #5
dangus is offline dangus  Canada
I generally buy Mueller alligator clips and make my own leads. Their clips are little works of art, with jaws that mesh perfectly.
Old 4th November 2016, 10:03 AM   #6
Solid copper !! Those are nice.....and available at digikey.
Cheers dangus
meuller.com
File Type: jpg Mueller BU-60C1. Solid Copper Alligator Clips..jpg (43.7 KB, 89 views)
Old 4th November 2016, 10:07 AM   #7
Edit that should be
http://mueller.co/wp-content/uploads/DS-BU-60C.pdf
Lesson learned RhythMick Construction Tips 6 3rd May 2016 11:20 AM
Tonight I learned a hard lesson on decap Fusion916 Solid State 40 29th March 2015 09:34 AM
Lesson learned - Do not use your Alpair 7's as test drivers. Munga Full Range 2 11th August 2012 11:07 PM
I learned A lesson in Grounding today! Zero Cool Solid State 2 29th December 2007 11:06 AM
Learned a lesson today Ralph Tubes / Valves 9 18th December 2003 05:35 PM
Copyright ©1999-2017 diyAudio
