Old Tuner - good case for Pi + HiFiBerry DAC? - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 5th October 2016, 09:55 AM   #1
bugbear is offline bugbear  United Kingdom
Default Old Tuner - good case for Pi + HiFiBerry DAC?
I have a hankering for a Raspberry Pi based sound system.
Pretty routine stuff;
https://www.hifiberry.com/dacplus/
RuneAudio - Embedded Hi-Fi music player
https://volumio.org/discover/
But I need a PSU (possibly a regulated one ) and a case.
I note that old tuners are very much unloved, at yard sales, car boots, flea markets, eBay.
Is an old digital tuner (slimline, simple facia, a few buttons) a practical source of a cheap
case (and possibly other parts) ?
e.g.
Technics ST-X902L
Or are there difficulties I haven't thought of?
BugBear
Old 6th October 2016, 05:48 PM   #2
chrisb is offline chrisb  Canada
On many small projects, the most frustrating / expensive part can be finding /fabricating a suitable chassis, so there's a lot of appeal to this type of recycling - and there certainly appears to be lots of available real estate in this case.
The only difficulty I can foresee is the number of control functions / display incorporated in the front fascia, which on this class of unit are usually an integral part of the chassis. They are often not designed for disassembly / repair, so take care in releasing any plastic retaining clips, etc.
Once those are stripped away, you'll have a lot of openings to fill / block off, and lettering to cover.
It would appear that the main AC switch is on a separate daughter board, which could make for easy retention of that function, and the power supply might well be adequate for at least some of the intended new components.
on hiatus
Old 7th October 2016, 07:52 AM   #3
I'll take that as a "yes", with caveats.
Thank you.
BugBear
Old 7th October 2016, 10:38 PM   #4
I think that's what I was getting at
on hiatus
Old 9th October 2016, 05:07 PM   #5
This is why I used an sx-3700 and sx780 to house new amp and preamp circuitry.
sx-3700 has an excellent tuner
sx 780 has power amp VAS stage regulators from separate transformer winding.
with Mosfet outputs instead of STK paks the 780 clips around 75w RMS 8 ohms !
Amps are very similar to Honey Badger Amp detailed in another thread.
both units easily accept a tube preamp with capacitor voltage doubler.
You could place your Raspberry Pi unit inside the case and dedicate the AUX or 1 Tape monitor input to it.
Old 10th October 2016, 04:14 PM   #6
Bare is offline Bare  Canada
Old Electronics contraptions cases are certainly recylclabe/ useable.
But a Pi with dac attached is about the size of a Cigarette package.
Talk about a little boy in a Cathederal :-)
Lotsa bespoke plastic Pi cases available from *many* sources from V cheap to; are you serious? pricings.
Also 1 $ stores carry an assortment of almost free 1/8" ply boxes in various sizes configurations which at least could be size appropriate with contained hardware.
Likely less coin than some clapped out Gear for it's case buy.
Imo a Regulated PS is Audio Weenie overkill.
But we all have our own belief systems.
A simple Battery is a Very clean reliable power source, worthy of trying out. Before futzing about on a 'suitable' PS quest
Going to buy/use a tablet screen for the above ?
Old 13th October 2016, 03:58 PM   #7
Part of the plan is that the resulting tuner-with-pi-and-power-supply will be a standard width "normal" hifi box I can simply add to my hifi rack.
As you say, a Pi is tiny; but that's not an undliuted Good -for example, it would likely just move around under the weight of the phono lead!
BugBear
Old 14th October 2016, 08:47 AM   #8
Damn.
I wanted to use the Pi 3's built in WiFi as part of Volumio's GUI, using either my laptop or tablet as the control.
But if I put the Pi in a metal case AKA Faraday shield that won't work...
Bugbear
Old 19th October 2016, 01:24 AM   #9
Originally Posted by bugbear View Post
Damn.
Bugbear
If you get a USB wifi adapter with an antenna, you could drill a hole in the back of the tuner and have the antenna stick out.
Something like this would be perfect:
Rosewill WiFi Adapter
Old 19th October 2016, 03:08 PM   #10
Jerms is offline Jerms  United Kingdom
Damn.
Bugbear
If you're brave....
External antenna modifications for the Raspberry Pi 3 | DorkbotPDX
J.
Hifiberry DAC+ Pro - HW mods anybody? soundcheck Digital Line Level 537 Yesterday 06:28 PM
My DAC for the Raspberry Pi usul27 Digital Line Level 156 29th April 2017 11:10 PM
Hifiberry/Pi case/PSU design questions bugbear Digital Line Level 1 25th August 2016 09:46 AM
Hifiberry digi (not digi+) for Raspberry Pi 2 Rene230781 Digital Line Level 0 3rd February 2016 01:05 PM
a tuner for $1.64 to rework and case jaudio Analogue Source 4 15th June 2008 03:22 PM
Copyright 1999-2017 diyAudio
