need advice - tall speakers, how to build a base, looking (cast concrete/cement?) - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 1st October 2016, 08:44 PM   #1
Default need advice - tall speakers, how to build a base, looking (cast concrete/cement?)
As the title kind of says, trying to build a base for my speakers, needs to be very low cost and heavy, was thinking of casting dyed sement/concrete, anyone have any idead or advice?
Old 1st October 2016, 08:52 PM   #2
Andersonix's Avatar
Make mold from plywood or Sonotube, and pour in concrete. Design the mold so it takes exactly half bag of 'ready mix.'
Or make base mold part of loudspeaker, so it can also hold sand as a first option, before you pour in concrete.
Old 1st October 2016, 11:10 PM   #3
expert in tautology
bear's Avatar
helps to know what the design looks like?
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 1st October 2016, 11:33 PM   #4
It's a tower, about 1m tall, front is about 19cm wide, rear about 7cm, curved sides.
Has three 8mm female threads inserted into the base - two at the front and one at the rear.
Bass port at the bottom - was using spikes to hold the bottom of the speaker approximately 1" of the floor, so if I make a plinth it'll maintain this gap.
Current thoughts are either to cast 100mm M8 threaded bolts into the base, giving a cement base about 7.5cm thick, which will add a lot of weight and hopefully stability.
other options I can think of are expensive...
Old 2nd October 2016, 12:09 AM   #5
expert in tautology
bear's Avatar
So, it is already designed and built?
Fwiw, I'd put the concrete inside the box, unless it is already built. Assuming you
want weight, not a wide base... and fwiw, I do not like downward facing ports, they
become too dependent on the floor material, and the height above the floor. YMMV.
1m is not terribly tall at all... so unless you need a tiny footprint, a wider wood base or other material (even case concrete or gypsum) will work
_-_-bear
Old 2nd October 2016, 04:33 AM   #6
Top Shelf's Avatar
Go to a local metal shop. Ask to buy 2 pieces of aluminum that measure 18" 18" 1/4" . Take them home and slightly radius all 4 edges of one side. Then, take some metal polish and shine that side up.
After that, bolt to bottom of speaker ( long bolts and spacers)and enjoy.
JEREMY M_________________________________
I like it loud, BUT NOT TOO LOUD!.... Hey do you hear that high pitched ringing sound ?
Old 2nd October 2016, 07:30 AM   #7
GM is offline GM  United States
GM's Avatar
FWIW, I've made my own, but precast concrete slabs in various size are available relatively cheap nowadays: https://www.google.com/search?q=pref...cT_AlcQsAQIogE
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 2nd October 2016, 07:07 PM   #8
Yeah they're already made. I think a large part of the problem comes from having a single spike at the back, centre of gravity is pretty high and near the front of the speaker, so they topple easily.
I was thinking casting so I could cast M8 bolts directly into the concrete, or holes so the concrete can bolt directly to the base, wider base and heavy so they cant knock over.
Putting further thought into it, I'm starting to think that maybe cutting out a more aesthetically pleasing shape from a lump of mdf may be a better idea, then I can have two "prongs" at the back to stop it toppling over... probably a better idea. and some kind of non-spike based feet would help, marking floors isn't cool
Old 2nd October 2016, 07:57 PM   #9
GM's Avatar
Agreed, however many layers of MDF it takes to ~match >50% of the speaker's weight is much easier to make, decorate with molding, etc., or just 'staircase' tapered. The finest looking 'marble' roman column/plinths I've seen were realistically painted MDF construction.
Industrial grade Velcro holds quite tenaciously BTW, so good that I've had to use a flat blade crowbar to pry them loose in some cases, so generally just use tabs of it rather than a continuous bead. Product/whatever trade show booth assembly, displays rely heavily on it.
GM
Old 3rd October 2016, 10:59 AM   #10
Ok, so here are some pictures of the cab and the base.
Am I right thinking there's a general agreement that a thick MDF Base is the way to go?
Also, If I want to avoid using spikes, what other ways are there to have the cab on the floor? reall it should be off the floor, or the bass port won't work at all...
Fostex FE83en CONCRETE HORN (advice) lagerfeuer Full Range 9 6th November 2013 02:12 PM
advice on build first speakers? smaki Multi-Way 11 26th January 2010 10:49 PM
Resin concrete tips? TT plinth/base. jeanvigo Analogue Source 13 15th May 2008 07:59 PM
Need advice reagaring speakers/amplifier build. cerupcat Full Range 0 12th November 2007 02:48 AM
Germans build concrete cast 5.1 speaker set Nordic Multi-Way 8 24th January 2007 08:20 PM
Copyright 1999-2017 diyAudio
