Hi
I have just found this forum after I have purchased a tda7492p bluetooth amp board so I wonder if I could use your expertise and knowledge to fettle my design whilst i wait for it to arrive. I'm just going to build a simple boombox as a first project but would like to use remote switching such as sprung loaded toggle switches instead of the onboard buttons that control everything. Does anyone have any tips or ideas on how to bypass these buttons?
Kind Regards
Beefy1
Kind Regards
Beefy1
Hi
Thanks for the reply. I've seen a build where he uses the same board but he uses screws and foam to extend the buttons, I'd like to extend them electrically and mount switches remotely. I might just have to experiment. The switches just look like momentary switches so hopefully it won't be too difficult to bastardise the board.
Beefy1
Beefy1
No need to remove those switches. You can solder hook up wire and extend.
Gajanan Phadte
Hi Gajanan
Thanks, that's what I was hoping for. Will give it a go when it arrives.
