3.5mm to RJ9 basic connection - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 14th June 2015, 01:49 AM   #1
Fsci123 is offline Fsci123  United States
Default 3.5mm to RJ9 basic connection
Hi everyone I'm new... I want to connect the an aux cord from and MP3 player and wire that into an rj9. I just want one way mono audio going from the aux to rj9. I'm thinking of taking the audio wires from both cords and twisting them together...will this work? Do I need some special circuit for this?
Old 14th June 2015, 04:39 AM   #2
DUG is offline DUG  Canada
Use two resistors so the two outputs don't fight each other.
Depending on output drive capabilities the resistors could be 100-1000 ohms.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 14th June 2015, 04:57 AM   #3
Is that required even though i have mono audio?
Old 14th June 2015, 02:52 PM   #4
What is your MP3 player?
I don't think I have seen a mono MP3 player before.
Old 14th June 2015, 05:54 PM   #5
Should it work if the audio coming from the player was in mono?
Boombox with AMP6-BASIC battery connection reemixed Class D 1 28th September 2012 12:03 PM
(DIY) 3.5mm jack adapter to 2.5mm output Rui Luis Instruments and Amps 4 6th September 2011 06:50 AM
WTB: 2.5mm plug to 3.5mm plug cable Relax Swap Meet 5 10th February 2007 12:13 AM
A basic chipamp in a not so basic case. waltson Chip Amps 19 24th August 2005 07:40 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
