Construction Tips Construction techniques and tips
Little powered speaker wiring help
Old 4th November 2014, 10:35 PM   #1
Ripcord is offline Ripcord  United States
Ripcord's Avatar
Default Little powered speaker wiring help
Ok, so I'm trying to figure out the best way to wire the power section of a little powered speaker that I'm making for a christmas present. I have a TPA3116D2 power amp that I made, a 12vdc battery charger that I also made. What I would like to do is put a switch in that cuts the battery charger out of the loop and applies the battery power to the amp, in one direction, and applies the battery charger to the battery and cuts the power amp out of the loop in the other direction. After I read what I just wrote I'm not sure if I really understand it. Anyway, I made a bad drawing of it. I'll take any ideas. Maybe a DPDT switch?
Old 4th November 2014, 11:11 PM   #2
Richidoo is offline Richidoo  United States
Nice gift!
A SPDT switch will be adequate because the grounds of battery, amp and charger can stay connected together all the time. The battery + goes on the middle terminal of the switch, and the amp+ connects to one side and the charger+ to the other side. You may want another switch to the amp to shut off the amp even when you are not charging it. I guess you could just unplug the charger.
Get a heavy duty switch with 10A rating to ensure good current carrying ability to reduce resistance which will affect the sound quality of the amp.
Old 4th November 2014, 11:18 PM   #3
Ripcord's Avatar
Thanks Richidoo. Also,I think I will add a switch to turn off the amp.
Old 5th November 2014, 12:50 AM   #4
Looking at my drawing I realize that a 3 position SPDT instead of a 2 position switch will allow the center switch position to be your off switch.
Old 5th November 2014, 01:38 AM   #5
Ripcord's Avatar
Actually, after looking through my parts bin I found this switch and thought it would work for what you suggested. It does have a center position. It's 250v 10A.
Old 5th November 2014, 02:07 AM   #6
OffGridKindaGuy is offline OffGridKindaGuy  United States
OffGridKindaGuy's Avatar
Wouldn't a diode work just as well in either the positive or negative lead to the charger between the charger and the battery? Add the switch between the battery and the amp.
Little powered speaker wiring helpHide this!Advertise here!
Please help - Capacitor wiring in battery powered amp nearlygnarly Construction Tips 10 9th September 2013 12:07 AM
Mackie Powered speaker problem argonrepublic Chip Amps 3 15th December 2011 10:44 PM
behringer powered speaker argonrepublic Instruments and Amps 9 2nd October 2011 12:46 AM
Ross Powered Mixer PC-4110MT transformer wiring ronthesoundguy Power Supplies 3 12th June 2010 04:11 AM
Constuction Help - Booming powered speaker kurtbauer Multi-Way 18 13th July 2007 09:43 PM
