Construction Tips Construction techniques and tips
amp in metal case, 2 questions
Old 4th September 2014, 02:35 PM   #1
gychang is offline gychang  United States
Default amp in metal case, 2 questions
1. I will be using 3.5mm audio input terminal as attached on the metal case, what is the easiest way to isolate it from touching the case?, I can see the correct size plastic/rubber washer but how about the "core" touching the case?
2. I noticed many builds have cables twisted to speaker terminals from the amp, should this be done on the audio input signal to amp also?, what is the reason?
thanks,
Good sound from Davis, CA
Old 4th September 2014, 02:45 PM   #2
thanks,
Old 4th September 2014, 03:13 PM   #3
rayma is offline rayma  United States
thanks,
Use either an insulating shoulder washer/flat washer combination (preferred), or in a large hole mount an insulating panel with mounting hole for the socket.
Send/return lines should be twisted, if they're not in the form of a coaxial cable. This is for shielding, to reduce interference and/or feedback from the output circuit.
Old 4th September 2014, 11:36 PM   #4
very helpful, where can I get "shoulder-washer" combo (sounds ideal).
not sure what u mean by send/return lines, (no coaxial). Audio input wires to amp?, speaker wires to RCA terminal?
Old 4th September 2014, 11:42 PM   #5
Yes, these are made by companies that make electronic hardware, like:
Flat Washer, Shoulder Washer, Nylon, Fibre: Keystone Electronics
The fiber types are much more rugged and temperature tolerant than the nylon types.
An unbalanced input has two wires, hot and cold. These should be twisted together on their way to the pcb, for example.
Think of the current as flowing in a loop. You want to keep that loop area as small as possible. The twisting averages out the effects of external fields.
amp in metal case, 2 questionsHide this!Advertise here!
Metal Case Safety Advice prighello Class D 20 12th June 2014 08:11 AM
Case and metal working Vikash Chip Amps 168 7th September 2004 10:24 AM
Recieved my Par-Metal Case PaulHilgeman Parts 3 3rd November 2003 04:50 PM
wood/metal laminate for case mltaunt Everything Else 5 7th November 2002 05:48 PM
