Capacitor wrap cutting brief tutorial - Page 3 - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 4th September 2014, 06:55 PM   #21
SY's Avatar
Originally Posted by SonyFan View Post
As far as the black- the evidence is right in front of you.
Google "black body." This is basic physics. It's not a surface area effect.
edit: Here's a table of emissivity for your future reference- http://www.engineeringtoolbox.com/em...nts-d_447.html
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 4th September 2014, 07:08 PM   #22
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
when Thermalright, a performance PC cooling products manufacturer, released three identical versions of their popular TRUE 120 heatsink. One came with aluminum fins and was meant to be a budget option, one came with pure copper fins, and one called the "Ultra" came with black anodized pure copper fins. Guess which one performed the best?
These objective tests are from two different hardware review sites.
http://i.imgur.com/7ac96KY.png
http://i.imgur.com/mIagrlf.png
Sorry but in this case the examples posted above are quite irrelevant.
They refer to FAN cooled heatsinks,
with tons of exposed internal surface for better exchange with the air flow, and very poor external surface exposure (which would help radiation).
In this case colour isnīt important, since I guess convection takes away 100X what radiation does.
Old 4th September 2014, 07:16 PM   #23
jcx is offline jcx  United States
the thermal engineering is is fairly well understood - and as in most engineering questions - it depends
convective cooling is conduction to the air, less barriers the better, some power law dependency from larger delta T causing more air convective movement
forced air movement with fans usually means thermal conduction of bare metal wins out
for radiation direction of heat transfer and efficiency depend on relative temperature differences, can become larger than convection for >100 C deltas for typical electronic assemblies, but is large power of the delta T and becomes very small for lower delta T
but it can be worthwhile to have better emissivity in low airflow speed natural convection, external heatsinks seeing ~20 C room
as mentioned internal heat from current ripple with ESR should be low in most audio equipment, in fact often the biggest life shortening threat to Al Electrolytics may be from being too close to other heat sources - especially tubes
so you can't make a blanket statement - there are differences depending on internal heat generation, air temperature and flow, flow resistance, relative temperature and solid angle between radiative sources and sinks...
Old 4th September 2014, 10:18 PM   #24
Enzo is offline Enzo  United States
I work in pro audio, where the internal cosmetics are not an issue. I am sure in the audiophile area, the internal appearance of an amp is a marketing concern at the very least.
So in my experience, when I open an amp and see caps with the end exposed like that, it is almost always because the heat inside the amp - not necessarily from the cap itself, it is surrounded by heat - has cause the cap wrapper to shrink, thus exposing its own end.
Old 4th September 2014, 11:49 PM   #25
JMFahey's Avatar
Well, even respected plumbers sometimes let sleeving slip somewhat and expose some of the inner works.
And in hot humid days, I bet it improves cooling.
Old 5th September 2014, 12:22 AM   #26
Speakerholic
Cal Weldon's Avatar
I wonder if he sells crack?
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 5th September 2014, 11:21 AM   #27
DF96 is offline DF96  England
As far as aluminum being a poor radiator I just don't believe it
As you live in a democracy you are of course free to believe or disbelieve anything you choose. Your belief does not affect the fact.
we don't make heat sinks or heat sink fins out of it for no reason.
Aluminium is cheap, light in weight, a good heat conductor and easy to machine. The best heatsinks are blackened to aid radiation. Convection does not worry about colour, but may be affected by surface roughness.
If the nude capacitors are hotter on the outside then they may in fact be cooler inside
Very unlikely, whether the heat source is inside or outside.
I would like to see more evidence supporting the idea that something black will run cooler just for being black.
I first saw the evidence in a standard school lab experiment when I was about 14. Later I learnt the theory in my physics degree. Note that if there is an external heat source then the black body will get hotter, as it absorbs more.
So the rule is not 'black things are cooler', but 'black things are better coupled to their thermal environment'.
Old 5th September 2014, 12:33 PM   #28
SonyFan is offline SonyFan  United States
SonyFan's Avatar
Anyone who wanted to do this and read these posts might be turned off now because they think their caps are going to catch fire and that is just not the case. That is the only point I have to make for the sake of this thread. Too much time has been spent arguing already.
"You lose, Rickles!" - Jim Lahey
Old 5th September 2014, 12:53 PM   #29
. . because they think their caps are going to catch fire . .
Perhaps just a minor exaggeration, in leiu of a coherent response?
One man's argument is another man's attempt at teaching basic physics.
To sum up this thread so far:
You think they look nice.
You didn't realise that the change might affect their ripple current rating, because of thermal radiation effects.
Old 5th September 2014, 12:54 PM   #30
Agreed, far too many posts alleging the impossible.
Learn some facts about heat and electricity and then come back with some sensible suggestions.
regards Andrew T.
Sent from my desktop computer using a keyboard
Carbon fibre vinyl wrap Assesears Full Range 3 27th January 2014 07:13 PM
Wire-Wrap vs. Solder phishead8 Equipment & Tools 12 24th May 2011 03:21 PM
Naim wrap ash_dac Everything Else 1 15th August 2006 09:35 PM
How wrap transformer... MaXiZ Power Supplies 6 13th May 2005 10:52 PM
Wrap-around veneering Gaber Multi-Way 10 2nd February 2004 09:23 PM
Copyright Đ1999-2017 diyAudio
