How to install heat sink? - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 31st August 2014, 12:34 PM   #1
gychang is offline gychang  United States
Default How to install heat sink?
I plan to install gainclone chip on aluminum case using it as a sink.
One concern is to have a good conductance at the point of contact yet to avoid grounding issues. Not sure how it is done.
do I add a silicon thermal grease as in PC, CPU? and a screw?, but then it will conduct, nylon screw?, I see some amps have a "pad" inbetween.
can someone enlighten me on this?
Good sound from Davis, CA
Old 31st August 2014, 01:06 PM   #2
For the TF version where the tab is insulated you can bolt using a steel screw (preferably with a washer) and just apply thermal goop between the tab and the sink.
For the T version where the tab is tinned copper you MUST insulate the steel fixing screw and insulate the heatsink.
Use a thermally conductive soft insulator between the tab and the sink.
Use a top hat plastic washer around the screw.
The narrow end of the top hat fits inside the tab hole. You must buy the correct size (for To220)
The wide side needs a load spreading washer under the screw head. Otherwise the washer deforms from the screw force and can eventually creep sufficiently to loosen the "grip" and overheat the chipamp.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 31st August 2014, 01:07 PM   #3
Electrons are yellow and more is better!
peranders's Avatar
Use the insulated TF package and some grease.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 31st August 2014, 05:21 PM   #4
thanks, now I know TF is the one I should use.
Old 4th September 2014, 04:17 AM   #5
SonyFan is offline SonyFan  United States
SonyFan's Avatar
Some companies call this "full pak" -- among other things. It's always the way to roll unless you have some specific need for the metal tab.
"You lose, Rickles!" - Jim Lahey
Old 4th September 2014, 11:18 AM   #6
Originally Posted by SonyFan View Post
................... It's always the way to roll unless you have some specific need for the metal tab.
"always" really?
It has a significantly poorer Thermal performance than the T version.
regards Andrew T.
Old 4th September 2014, 12:17 PM   #7
SonyFan's Avatar
Originally Posted by AndrewT View Post
"always" really?
Like thermal performance.
Heat Sink Heat Sink Sources for Pass Amplifiers manmohan singh Pass Labs 9 16th March 2012 11:37 PM
heat sink khimh Subwoofers 1 8th December 2011 12:50 AM
Where do I plug this into!? Help! ?Heat Sink? ltjenkem Solid State 11 23rd September 2011 09:07 PM
Is this heat sink OK? portreathbeach Chip Amps 5 28th February 2010 11:56 AM
How much heat sink is necessary? rosss Pass Labs 11 23rd February 2003 05:23 AM
Copyright ©1999-2017 diyAudio
