Tilting Midrange and Tweeter toward axis - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 17th August 2014, 01:31 AM   #1
Default Tilting Midrange and Tweeter toward axis
I'm building a pair of satellite midrange/tweeters with a single sub-woofer. It seems that tilting (wedging) the MR and tweeters of each satellite slightly toward a common axis for each speaker, focused on the primary listening area, would help with imaging since the MR and tweeter would then have identical path lengths to the listener. I'm sure I'm not the first to consider this, but cannot find a discussion of any drawbacks.
Old 17th August 2014, 04:47 PM   #2
anirban420's Avatar
The effect will be so minimal that you can not *FEEL* it
Old 17th August 2014, 05:07 PM   #3
picowallspeaker's Avatar
Full direct planar wave edge extrapolation management through parallel quasi coincident dual channel
Old 17th August 2014, 06:05 PM   #4
This app note discusses the subject: http://www.bruelkjaer.de/doc/17-198.pdf. I believe it is more important to align the acoustic centre of the drivers. E
On the hunt for the great off-axis tweeter response Lindell Multi-Way 2 9th March 2009 01:52 AM
Zaph's L18 with Tweeter in axis check Multi-Way 6 21st February 2007 01:09 PM
any research into off axis response Vs tweeter face profile Puggie Multi-Way 5 8th February 2006 09:23 PM
Multiway off-axis irregularity - causing midrange distortion (Long post) jesper Multi-Way 22 3rd February 2005 10:33 PM
Copyright 1999-2017 diyAudio
