How to remove lettering from chassis - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 10th March 2014, 09:55 PM   #1
Neville is offline Neville  United States
Default How to remove lettering from chassis
Hi there, I bought a chassis with some lettering on the front panel I would like remove so its generic. I have tried Isopropyl and nail polish remover with no success.
I thought I saw a thread on this but can't seem to find it now. I know there is one on how to put lettering on a chassis but I want to get rid of a manufactureres name on mine.
Thx in advance
Neville
Old 10th March 2014, 11:32 PM   #2
DUG is offline DUG  Canada
Did you try paint remover?
Is there paint between the lettering and the metal?
If there is and you only want to remove the lettering then don't use paint remover.
A picture might help.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 10th March 2014, 11:59 PM   #3
Hi Dug, there is no paint, just letters on stainless steel. Have not tried paint remover yet. Will have to see if I still have any. Are there any other household items I could also use?
Old 11th March 2014, 12:03 AM   #4
Budgie is offline Budgie  United States
I use "Jasco" paint and epoxy remover. I used it on anodized aluminum without any problems. I would try a test patch in an out of the way spot first anyway, just to be safe.
Old 11th March 2014, 12:16 AM   #5
lgreen is offline lgreen  United States
lgreen's Avatar
Default Removing lettering
2 threads-
How to Remove Writing from HP Front Panels?
The Magic of Sugar Cubes
Retired from DIY (2010) but still lurking now and again. My DIY audio projects- PartTimeProjects.com.
Old 11th March 2014, 12:17 AM   #6
Paint remover/thinner did not work on it. But here is pic of it.
File Type: jpg $T2eC16d,!y0E9s2S7)Y-BR1velh1mQ~~60_57.JPG (174.9 KB, 113 views)
Old 11th March 2014, 12:34 AM   #7
Originally Posted by lgreen View Post
Wow...will regular grains of sugar work? I assume rubbing it left to right with a cloth until its removed?
Thx
Old 11th March 2014, 03:49 AM   #8
Are you sure that's stainless steel? It looks like hardened aluminum to me and those may be anodized. If so there is no way to get them out short of grinding.
Old 11th March 2014, 05:09 AM   #9
Orbital sanders make a nice pattern...then clear coat it.
Old 14th March 2014, 10:06 AM   #10
You can also hide it behind a metal plate pasted over it that contains your writtings.
Gajanan Phadte
Chassis Lettering - What works? vdi_nenna Construction Tips 49 8th March 2014 12:49 PM
Wanted: McIntosh 40 chassis with good lettering hatrack71 Swap Meet 2 13th November 2012 09:37 PM
How to remove knicks on Krell Heatsinks/chassis john65b Solid State 3 16th January 2009 11:56 PM
Lettering on transparent panel GRollins Everything Else 42 4th February 2007 04:19 PM
Copyright 1999-2017 diyAudio
