Construction Tips Construction techniques and tips
Need filler for letters punched in wood
Old 10th March 2014, 02:55 AM   #1
BillEpstein is offline BillEpstein  United States
BillEpstein's Avatar
Default Need filler for letters punched in wood
Anybody use punch sets to letter wooden chassis? Recommend a filler that remains after wiping and dries hard?
Old 10th March 2014, 01:34 PM   #2
wicked1 is offline wicked1  United States
wicked1's Avatar
A punch on wood?
I've used acrylic paint and wax on plastic and metal projects. Ink is sometimes used, but that's probably too thin for wood. Used an automotive paint touch up pen once (on plastic).
I'd probably go for medium thick acrylic paint. Apply w/ a tooth pick, to fill the letters. Dry. Apply again to be sure it's flush or a bit over filled when dry. Let it dry completely (up to a couple days). Then sand away the excess.
I'd be afraid wax would sink into the grain, and not accept your final finish.
--I did a quick search and acrylic is not compatible w/ an alcohol based top coat, as it may dissolve the acrylic. Anything else (water or oil based) should be fine.
Old 10th March 2014, 01:58 PM   #3
Peter M. is offline Peter M.  Norway
You could use epoxy mixed with wood dust, metal dust, marble dust or something else.
I haven`t tried it with punched letters, but it works fine with carved letters.
Whatever you use for a filler make sure that you seal the wood first.
Note to myself: Never again use fingers to check if there still is voltage left in a capacitor...
Old 10th March 2014, 02:47 PM   #4
kuroguy is offline kuroguy  Germany
kuroguy's Avatar
you can use wood filler. comes in many colors to match different woods and goes on like putty. once hardened, sand off the excess and you should be left with a nice flat filled letter. post in construction tips and you might get more responses.
"The magnet wire used to come from Radio Shack. In keeping with their policy of figuring out what the best products are and discontinuing them they no longer have it." - Max Robinson
Old 10th March 2014, 04:04 PM   #5
Refugee1 is offline Refugee1  United Kingdom
Refugee1's Avatar
I have used a mixture of Tip-Ex correcting fluid with an xylene based conformal coating for vintage Bakelite front panels and it has worked well for me.
The correcting fluid is too powdery on its own and the conformal coating makes it more durable and tames down the brightness of the bright white of the fluid.
I used a tooth pick to apply it as others have done here.
Old 21st March 2014, 05:56 AM   #6
LazyH is offline LazyH  United States
Something else that might be good to try, placing a wet rag over the wood for about a half hour then using a clothes iron through the cloth, expands all sorts of dents and punches in wood, let it dry then sand and fill if needed, it'll make the filling less noticeable even if it won't completely remove the punches in the wood.
Old 21st March 2014, 09:35 PM   #7
chrisb is offline chrisb
I note the question has yet to be asked as to intended finish after the "repair"
If there's any depth to pores of wood grain, it could be very trick to fill just the punched letters, and to get a deadly match on color of fill if attempting to retain close to original finish.
If it's solid wood and thick enough to permit doing so, I'd be inclined to plane / sand down to slightly below the level of impressions (to avoid telegraphing the stress on fibers from the punching) and refinish.
On the other hand, if to be painted over, then any decent resin bondo type product, and a few coats of high solids primer and then your color & top coats, and you'll be good as new.
kinda burnt out - taking a break
Old 21st March 2014, 10:12 PM   #8
Einric is offline Einric  United States
Einric's Avatar
I used a standard steel stamp set and heated them with a torch.
Then I stamped the wood and it burned the lettering in.
Once you apply your finish it will be permanent.
Old 21st March 2014, 11:39 PM   #9
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
epoxy glue and sanding might make the letters look smooth
sometimes we know very little, and sometimes we know too much
Old 22nd March 2014, 02:49 AM   #10
See #7 above - in my opinion the desired final finish( not yet specified?) will dictate the approach & materials used.
Need filler for letters punched in woodHide this!Advertise here!
Help Wanted: Need some drilling and holes punched. Mull3t Swap Meet 10 4th July 2013 01:10 AM
FS: Tube Amp Chassis - finished, punched ready to build bear Swap Meet 12 2nd February 2010 09:00 PM
transistor letters Zorac Parts 10 13th October 2007 03:00 PM
Filler for mitered wood edges that aren't flush? riotubes Everything Else 4 22nd October 2006 02:25 AM
Allergies to Plastic Wood Filler seangoesbonk Everything Else 6 26th October 2003 03:31 PM
Copyright ©1999-2017 diyAudio
