Recommended glue for glueing plywood to MDF? - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 27th February 2014, 10:16 PM   #11
chrisb is offline chrisb  Canada
Well that's probably more important really for "veneering" i.e. thin raw or backed veneers, than for the described application of finished plywood skins ( I assume no thicker than 1/4"). For adhering such skins with glue rather than contact cement, you'll need to be sure you've got evenly distributed pressure to ensure full adhesion, either by vacuum bagging or cold pressing with platens of scrap material larger than the face panels and weights. It might not take tons of weight to equal the pressure of 14.7 lb psi., but it's the uniform distribution of that pressure while the glue is drying that counts.
on hiatus
Old 27th February 2014, 10:29 PM   #12
Thanks again Chris, superb advice. So for my plywood skin I use PVA glue, then use something bigger than cabinet surface for even distribution with weights on top.
Making sure the cabinet surface is flat first.
Old 28th February 2014, 08:03 AM   #13
Did it Himself
richie00boy's Avatar
Originally Posted by Stewart Holmes View Post
Thanks Andrew, do you think I should apply glue on the end grain of the MDF let it dry, sand it, then apply the plywood?
I wouldn't do that, it's simply not necessary to seal MDF end grain on a simple butt jointed box. In fact you will probably make it weaker as PVA doesn't stick very well to itself.
I also wouldn't bother sanding the good faces down either. Just make sure they are clean and free of dust and fingerprints and oils etc. PVA will soak in no problem.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 28th February 2014, 10:12 AM   #14
Cheers Richie for your advice it's easy to do things the hard way and appreciate all the advice.
Old 28th February 2014, 07:06 PM   #15
richie - if not clear my comment re sanding the MDF was in the context of veneering.
I've found it gives much better adhesion when using the iron-on method and yellow PVA glue, and since you'll want to sand all exposed joints anyway to clean up squeeze out and telegraphing of less than perfect seams, it doesn't really take all that much longer with a RO sander.
on hiatus
Old 28th February 2014, 07:30 PM   #16
Speakerholic
Cal Weldon's Avatar
Originally Posted by chrisb View Post
squeeze out
That's a much nicer term than bleed out, I think I'm going to adopt it.
Just saying it sounds nice.
planet10 needs your help:
Let's help Ruth and Dave
Old 14th March 2014, 11:33 AM   #17
I've ordered some Titebond II for the plywood skin on my MDF cabinets.
I were going to get PVA but I got a good deal on the Titebond II.
Should I use a roller or brush on application and I am right by gluing both sides?
Old 14th March 2014, 12:14 PM   #18
kuroguy is offline kuroguy  Germany
kuroguy's Avatar
when applying titebond, I like to use a squeegee (the edge of a credit card works well) and I like to apply it to both surfaces. A brush or roller applies way too much glue. Also, make sure to get 100% coverage of the surfaces with glue.
"The magnet wire used to come from Radio Shack. In keeping with their policy of figuring out what the best products are and discontinuing them they no longer have it." - Max Robinson
Old 14th March 2014, 12:45 PM   #19
Thanks kuroguy much appreciated, I've the perfect spreader in mind for the job.
Old 15th March 2014, 11:29 AM   #20
There's a lot of movement in the first 30 minutes after applying the weight, yet had no problems so far.
Iv'e done the back panel of the cabinet first and its had weight on for 15 hours, should I leave it for 24 hours before removing the weight and trim the edges? Thanks again.
Glueing MDF enough? protos Multi-Way 23 24th April 2015 09:17 PM
Glueing 3.6mm plywood or veneering for best sound? Stewart Holmes Multi-Way 4 14th February 2014 04:56 PM
mdf or plywood? grandemahatma Full Range 72 22nd October 2013 10:51 PM
Plywood or MDF? greg_mcquaid Subwoofers 30 10th July 2011 06:37 AM
Plywood not glueing well amo Multi-Way 7 17th July 2004 02:27 AM
Copyright 1999-2017 diyAudio
