Chassis Lettering - What works? - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 19th February 2014, 08:05 AM   #11
chienmort's Avatar
After the decal is dry ( about 24 hours ) i spray it with clear acrylic. It is really tough and gives a profesional finish.
Old 19th February 2014, 10:30 AM   #12
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
I'm going to try this outfit. It looks easy enough. Laser Waterslide Decal Paper
Less than $1 a sheet. Worth a try.
Will let you know how it turns out and post pics.
Vince
I build, therefore I am.
Old 19th February 2014, 10:36 AM   #13
KatieandDad's Avatar
Before you spray any form of laquer on it, I'd do a quick test. Some of these decals are easily dissolved by the solvents used in aerosols.
Old 19th February 2014, 10:39 AM   #14
Bixbacon's Avatar
Default Model planes
Hi Vince, the stickers that came with model planes were similar to this product from memory.
Its not worth saying, if it's not heard wright.
Old 19th February 2014, 10:50 AM   #15
vdi_nenna's Avatar
Was thinking of using a bottle of clear nail polish with a brush applied to only the decal and minimal surrounding area.
Is there anything better or safer for the decal?
Old 19th February 2014, 11:37 AM   #16
Hey,
I too have looked at this subject previously. Try searching "letraset" on google. Its a dry rub on transfer which i found still available fairly cheap in the uk on fleabay.
I have used this and if you want i can provide photos of the amplifier i tried it on.
Old 19th February 2014, 11:43 AM   #17
vdi_nenna's Avatar
Originally Posted by Kermit100 View Post
Hey,
I just ordered the wet decal sheets, but would like to see your work. I think this one aspect of chassis builds thats missing. Not everyone can afford or wants laser ethching. Most of the gear I built is in fact built and I'm not taking it apart to have it professionally labeled. Seeing other people's work is inspirational. Post your pics here.
Vince
Old 20th February 2014, 05:15 AM   #18
fret is offline fret  Australia
I had Sign-a-rama print my design on to a sticker than I then applied to my chassis:
Old 21st February 2014, 03:01 AM   #19
I've used clear peel-off printable labels. Print 'em and apply...
Avery, from the office supply store. Spray over for permanant.
Old 21st February 2014, 03:05 AM   #20
jackinnj's Avatar
You can get a great silk-screen kit from Michael's Stores.
Barring this -- my company has a CO2 laser about the size of a VW Bug and we could blast anything you want onto aluminum or steel and it definitely won't wear off.
Help ID this tube ^&$**@# lettering! Richard Ellis Tubes / Valves 5 11th April 2013 11:49 PM
Wanted: McIntosh 40 chassis with good lettering hatrack71 Swap Meet 2 13th November 2012 08:37 PM
DIY amps front panel lettering KenP Solid State 40 2nd February 2011 10:19 AM
Lettering on transparent panel GRollins Everything Else 42 4th February 2007 03:19 PM
Copyright 1999-2017 diyAudio
