Construction Tips Construction techniques and tips
Chassis Lettering - What works?
Old 23rd February 2014, 02:52 AM   #21
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
Chassis Lettering - What works? Send a message via Yahoo to vdi_nenna
Face plate pic of decal.
I build, therefore I am.
Old 23rd February 2014, 02:59 AM   #22
Bixbacon is offline Bixbacon  Australia
Bixbacon's Avatar
Looks great Vince, have you coated the decal with anything after applying?
Its not worth saying, if it's not heard wright.
Old 23rd February 2014, 03:20 AM   #23
vdi_nenna's Avatar
Thanks. Someone suggested spraying clear coat and I think its a good idea because off axis the brush on clear coat shows much more. A complete, even coat on the face would be better.
Thanks for all your suggestions. Much appreciated.
Vince
Old 23rd February 2014, 02:05 PM   #24
vdi_nenna's Avatar
Back side.
Old 23rd February 2014, 02:54 PM   #25
On Hiatus
SY's Avatar
Originally Posted by jackinnj View Post
You can get a great silk-screen kit from Michael's Stores.
+1. Silk screening is easy, and if you use a two part epoxy ink and bake it, the legends will outlive the user.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 24th February 2014, 01:35 PM   #26
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Came across a video on screen printing metal, glass -- How to Screen Print: Graphic Inks, Sticker Printing, Glass, Metal Signs and More - YouTube -- a bit different from textile as 2 part epoxies or solvent based systems are used.
Old 24th February 2014, 02:23 PM   #27
Bonsai is offline Bonsai  Europe
Sounds interesting.
I cany help thinking that on aluminum, you want to be able to laser print a decal on some kind of sticky label. Then, you put this onto your panel, develop it so all the letting areas are clear - I.e the decal dissolves there. Then you etch it for a period then stain it.
Then you remove the ensign decal (peel it off) and you are done.
Spray with lacquer if needed.
Now. Who can make a product like this.
Old 24th February 2014, 03:20 PM   #28
jackinnj's Avatar
One in the US is Bel Inc.
Laser Waterslide Decal Paper
Old 24th February 2014, 04:05 PM   #29
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
I tried all, in the long run had to learn screen printing, which is the Pro way.
*ANY* ink on *ANY* substrate, be it metal, paper, rubber, glass, whatever.
Have done it even for single use, go figure.
Here I'm printing one of my Bass amps front panel :
That said, sometimes I cheat and for a single prototype I inkjet print on self adhesive coated "magazine paper" .
Ask at a printing supply house and they'll know what you are talking about.
Comes in, say 3 by 4 ft sheets or whatever a commercial offset printer uses, but you cut it to size.
It's the material used for sticky labels.
You apply it on the panel (be careful to avoid bubbles), and clear coat it with some varnish.
Old 24th February 2014, 04:13 PM   #30
vdi_nenna's Avatar
That's the paper I used.
Chassis Lettering - What works?Hide this!Advertise here!
Help ID this tube ^&$**@# lettering! Richard Ellis Tubes / Valves 5 12th April 2013 12:49 AM
Wanted: McIntosh 40 chassis with good lettering hatrack71 Swap Meet 2 13th November 2012 09:37 PM
DIY amps front panel lettering KenP Solid State 40 2nd February 2011 11:19 AM
Lettering on transparent panel GRollins Everything Else 42 4th February 2007 04:19 PM
