Construction Tips Construction techniques and tips
Home Brew PCBs
Home Brew PCBs
Old 6th March 2014, 04:58 PM   #81
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
Originally Posted by KatieandDad View Post
Sorry about the misunderstanding.
The process with the negative film is also very simple, the beauty is that you can re-apply the film if you make a mistake.
1. Take the photo negative film and cut it to size.
2. Clean the copper clad board with fine abrasive paper and wipe clean with mentholated spirit.
3. Peel the thicker film off the photo negative film and apply the film to the copper board carefully removing any bubbles of air.
The film can be lifted and reapplied without any problems at this stage.
4. Pass the board through a laminator or iron it with a moderate iron to set the emulsion onto the copper.
5. Expose the board with a photo negative with a UV light source.
6. Remove the upper film from the photo resist.
6A. Develop the board in proprietory developer (Baking Soda)
7. Now you can etch it in the normal manner with Ferric Chloride (or the etchant of your choosing).
8. The film peels off easily after soaking in a caustic soda solution.
Whoops - missed a step.
Old 7th March 2014, 10:53 AM   #82
MrSleepy is offline MrSleepy  United Kingdom
Those are the exact steps needed for adding a 3m solder resist as sold by Mega.
I'll have to see if the 3M solder resist can be used on bare copper as an etch resist aswell.
Rob
Home Brew PCBsHide this!Advertise here!
New home brew amp module CBS240 Solid State 60 14th September 2017 11:18 PM
home brew woofer tester hitsware Equipment & Tools 4 9th February 2013 07:13 PM
problems with preamp on home brew jeeptechfred Tubes / Valves 2 17th May 2011 12:13 AM
Home Brew Ampeg B25B JJWright Construction Tips 2 13th April 2011 06:50 PM
The PINNACLE of Home Brew Amps - Or Not... camshaft Solid State 14 26th March 2008 11:13 AM
