Home Brew PCBs - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 11th February 2014, 10:11 AM   #11
KatieandDad's Avatar
Anyone watching this topic will realise that I have several experiments going on at the same time. I'm just waiting for the post to catch up with my ordering to progress each one.
I've found that my Epson R800 will quite happily print onto copper, or any flat board for that matter.
What I need now is some kind of water soluble primer to coat the copper board with so that the ink will stick and not run.
On the net I have read that a weak gelatine solution might work.
It has to produce a starch like film on the surface of the copper that will absorb the ink but also must be able to be washed off to revel the copper to be etched.
The primer that has absorbed the waterproof pigment needs to remain.
Seems like an impossible quandary.
Old 11th February 2014, 10:34 AM   #12
Bixbacon's Avatar
How about PVA, wood glue?
Its not worth saying, if it's not heard wright.
Old 11th February 2014, 11:42 AM   #13
A possibility, I don't think it is porous though, in fact isn't it the opposite ?
I've just tried Dylon starch spray. It layers on the starch too thick so you have to wipe most of it off but the ink did stick to it without running.
OK, I didn't leave it to fully dry as I'm only experimenting but the pigment and the starch washed off under a running tap.
Old 11th February 2014, 12:09 PM   #14
jkuetemann's Avatar
Your etching solution is aqueous and I'd expect it to wash off your ink 'resist' if you prime your boards with something water soluble. Simple surface roughening with steel wool isn't enough to keep the ink on the board?
---Jason Kuetemann---
Power is only granted to those willing to lower themselves enough to pick it up.
Old 11th February 2014, 12:29 PM   #15
Would machinists ink work? It's a coloured ink that's sprayed onto metal surfaces. It goes on very evenly from a spray can however it must be available just in its raw state. If that could be printed onto a PCB via a print head and it wasn't soluble in the etch you would have a viable printing system. After etching you would just clean off the inked areas with a solvent. Machinists ink dries very quickly when sprayed.
Old 11th February 2014, 12:37 PM   #16
There is an etch resistant ink but it seems impossible to get in small quantities. I chased it on the internet and I can get 250mL for 200.
Old 11th February 2014, 12:38 PM   #17
Unfortunately not, the ink just flows down the grooves caused by roughening the surface.
Old 15th February 2014, 11:39 AM   #18
Well the sublimination process was a failure.
The board would need to be painted with a polymer adhesion promoter which in its own right then waterproofs the board against the etchant.
I am making progress however with a more opaque image for conventional photo boarding.
Old 15th February 2014, 11:28 PM   #19
dirkwright's Avatar
Originally Posted by Absconditus View Post
150 pounds????????????? Surely not. There are a few companies doing PCB pooling, outsourcing manufacture and then mailing the cut-outs to the individual customers. Last year, I had four boards (all the same and 50 by 75 mm) done for $40 Australian.
There is a fellow from Romania (I think) who advertises cheap boards on the forum. I think he is "msdesigner".
Abs
But, what if he doesn't want cheap boards, but high quality instead? I used Pad2Pad and typically pay $110 or so for 6-8 boards, depending on size. These are double sided, 1oz copper, full solder mask, through plated holes and silk screened. I don't think it's terribly expensive for the quality I get.
Old 16th February 2014, 05:21 AM   #20
150 - YES !!!
The company that I use is in America. The cost for 2 x boards (their minimum) is approximately 80. Then add P&P and Handling - approximately 30. Then the criminal bit is UPS then add a further UK handling charge of approximately 30 which includes Import Tax.
I appreciate there are cheaper options but these guys are VERY quick, I usually get the boards two to three days after ordering.
New home brew amp module CBS240 Solid State 51 25th August 2015 07:31 AM
home brew woofer tester hitsware Equipment & Tools 4 9th February 2013 07:13 PM
problems with preamp on home brew jeeptechfred Tubes / Valves 2 17th May 2011 12:13 AM
Home Brew Ampeg B25B JJWright Construction Tips 2 13th April 2011 06:50 PM
The PINNACLE of Home Brew Amps - Or Not... camshaft Solid State 14 26th March 2008 11:13 AM
Copyright 1999-2017 diyAudio
