Construction Tips Construction techniques and tips
How to seal gaps is wood?
Old 26th January 2014, 08:51 PM   #1
guangui is offline guangui  Puerto Rico
Default How to seal gaps is wood?
Hi! I don't have a table saw, and I don't like doing long cuts with my circular saw because they are not the straightest. So, last time I gave the lumber store a list of cuts I wanted from a 4' x 8' panel of 1/2" MDF. Most of the cuts are straight and to the dims I gave him, except one. Because of that I have a horizontal gap between the base of the speaker enclosure I'm building, and the bottom part of the back. The gap is 4" wide by approx. 1/8" tall. The speakers will be veneered or painted, don't know yet, most probably veneered.
Here are my questions:
1. If I use veneer to cover the speaker cabinet, should I just seal the gap with silicone or should I use 2-Part epoxy? I will use an iron to apply the veneer.
2. If I paint, should I use 2-Part epoxy or wood filler? Being such a large gap I don't think wood filler will work well.
What are your recommendation?
Old 26th January 2014, 09:08 PM   #2
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
simply glue some wood, thick veneer, or something, in the place where some is missing
and then 'recut', or whatever you can manage
if already assembled, I would suggest to try and make some venner fit, to be pushed in the gap with glue
could even be small bits, one by one
sometimes we know very little, and sometimes we know too much
Old 26th January 2014, 09:14 PM   #3
Being a begginer at this I had already assembled, but I believe I can cut a piece with my miter saw and make it fit...Thanks!
Old 26th January 2014, 09:24 PM   #4
not sure how much is missing
just remember such pieces of wood sometimes breaks easily
btw, a sharp knife can be a very good tool
Old 26th January 2014, 09:28 PM   #5
evanc is offline evanc  United States
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
Bondo....
http://www.evancotler.com
Old 27th January 2014, 05:52 AM   #6
Thanks! I measured the gap, and it was 1/16" (2 mm) on one end and 1/8" (3 mm) on the other end. So, I cut a piece of 1/2" thick (13 mm) panel with those dims x 4" long (102 mm). Then I "painted" the cavity and piece of wood with glue and inserted it, it was a perfect fit and I had to tap it with a plastic mallet for it to go in. Problem solved...
Originally Posted by evanc View Post
Bondo....
Knew this solution, and totally forgot about it. I didn't feel like going to Home Depot and paying $25.00 for Bondo, when I can buy it at almost half price from the local auto bodyshop supplies store. Hopefully I won't forget next time...Thanks!
Old 27th January 2014, 10:32 AM   #7
geraldfryjr is offline geraldfryjr  United States
Glue and sawdust mixed together and pushed into the smaller cracks works well also, much cheaper than Bondo!!
jer
Old 27th January 2014, 11:47 AM   #8
jer
Great solution...I have plenty of that, as I collect it and store in a sealed contai er, to be used for household chemicals and garage oil spills...Homemade particle board.
Old 27th January 2014, 05:42 PM   #9
chrisb is offline chrisb
Bondo....
beat me to it
kinda burnt out - taking a break
Old 28th January 2014, 12:50 AM   #10
lowtherdream is offline lowtherdream  Canada
lowtherdream's Avatar
QuikWoodŽ - Epoxies and Adhesives - Polymerics Systems, Inc.
I really like the stuff
surfing the 2nd harmonic ... @@@@
How to seal gaps is wood?Hide this!Advertise here!
Digi-Gaps xstreme Software Tools 0 14th April 2013 04:57 PM
seal wood on inside of speaker cabinet? pizzachef Construction Tips 2 5th September 2011 08:19 AM
seal wood inside cabinet pizzachef Full Range 23 2nd September 2011 01:10 AM
Spark gaps on output transformers tomchr Tubes / Valves 8 19th February 2011 10:51 AM
Gaps in my horn - a major problem? wixy Full Range 6 7th September 2007 01:18 AM
Copyright ©1999-2017 diyAudio
