How to seal gaps is wood? - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 28th January 2014, 11:03 PM   #11
dangus is offline dangus  Canada
Mix sawdust with epoxy? Wood glue doesn't always like to be sanded.
Or, better, probably, use a router to trim things flush.
Old 28th January 2014, 11:56 PM   #12
guangui is offline guangui  Puerto Rico
Using Epoxy with dawdust makes sense. I have a router, but in all honesty don't know how to use/control it. When I practice, instead of a nice cut, the wood ends up burned or with chunks missing.
Old 30th January 2014, 01:42 PM   #13
kuroguy is offline kuroguy  Germany
kuroguy's Avatar
epoxy/sawdust is much harder to sand than wood glue/sawdust. the epoxy softens up under the heat and clogs the sandpaper.
"The magnet wire used to come from Radio Shack. In keeping with their policy of figuring out what the best products are and discontinuing them they no longer have it." - Max Robinson
Old 30th January 2014, 04:31 PM   #14
chrisb is offline chrisb  Canada
There are different types of epoxies
Bondo type auto body fillers are specifically engineered to be sanded / shaped - when mixed in proper hardener ratio and properly cured, clogging is far less of an issue. Wurth is a particularly finely textured and smooth filler.
... so, not as easy at it sounds, this letting go thing
Old 30th January 2014, 04:52 PM   #15
kuroguy's Avatar
my bad. when I hear Epoxy, I immediately think of the clear resin. you do not want to have to sand that stuff.
Old 30th January 2014, 05:42 PM   #16
Cut an old paint stick & trim it to size or sub floor calking.
The stuff you don't know always humbles us.........
Old 30th January 2014, 06:25 PM   #17
I am certified in installing FRP pipe and doing FRP structural work, so I know epoxy and the different kind. Bondo is a very good solution, but there are a lot of epoxys that can be used. In my home I use one sold at the hardware store, even at Walgreens or CVS that is "brownish", it comes in a two-part syringe and it is easy to mix, no need to measure. This one is very strong and easy to sand, will not clog the sandpaper. But, Bondo is still easier to work with.
Old 10th March 2014, 03:51 AM   #18
BillEpstein's Avatar
Originally Posted by evanc View Post
Bondo....
+1
Old 10th March 2014, 05:07 PM   #19
Speakerholic
Cal Weldon's Avatar
Originally Posted by guangui View Post
Then I "painted" the cavity and piece of wood with glue and inserted it, it was a perfect fit and I had to tap it with a plastic mallet for it to go in. Problem solved...
I think that's along the lines of what I would have done. Glad it worked out.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 10th March 2014, 05:30 PM   #20
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
constructing a new bass box right now
and had a few like this one
for strongest possible result I decided to glue the wood plugs with 2-component epoxy
sometimes we know very little, and sometimes we know too much
Digi-Gaps xstreme Software Tools 0 14th April 2013 04:57 PM
seal wood on inside of speaker cabinet? pizzachef Construction Tips 2 5th September 2011 08:19 AM
seal wood inside cabinet pizzachef Full Range 23 2nd September 2011 01:10 AM
Spark gaps on output transformers tomchr Tubes / Valves 8 19th February 2011 10:51 AM
Gaps in my horn - a major problem? wixy Full Range 6 7th September 2007 01:18 AM
Copyright 1999-2017 diyAudio
