Construction Tips Construction techniques and tips
3 speakers and a sub woofer set up
Old 16th January 2014, 11:09 PM   #1
somadas is offline somadas
Default 3 speakers and a sub woofer set up
I'm trying to build a speaker cabinet with 3x10cm car speakers at the top and one 12" sub woofer bellow. They are all 4 ohm speakers. Can anyone recommend what amp I might need and possible wiring to hook it up? I've tried searching but haven't found much advice with a 3 speaker setups. Any help would be appreciated.
Old 18th January 2014, 05:54 PM   #2
Andersonix is offline Andersonix  Sweden
Andersonix's Avatar
You don't really have any choice but to hook the three of them in series to make 12 Ohms. But try them mounted in a cardboard box before spending any real effort on a real box.
Old 18th January 2014, 06:47 PM   #3
Brian Oshman is offline Brian Oshman  United States
A bridgeable amp can run tri mode. Hook two up stereo and the sub mono bridged simultaneously.
Old 18th January 2014, 07:01 PM   #4
chris661 is offline chris661  United Kingdom
chris661's Avatar
Maybe, but given they're all 4-ohm drivers, you'll be loading each channel at something silly like 1.3ohm. That's just plain abusive.
Some amps will stand it, and just sit there and get warm. Others will shut down after a little while. The rest will just release the smoke.
Old 19th January 2014, 08:20 AM   #5
Ive looked into the impedance and if I have 3 in series it will give 12 ohm and if they are wired parallel I will get a 1.3 ohm load. I don't know what sort of effect either will have on the amp as this is my first build. I have already built the box but was worried as to which amp to choose to run it as I don't want it to blow.
3 speakers and a sub woofer set upHide this!Advertise here!
Jazz speakers and SET intojazz Full Range 18 4th February 2016 01:05 PM
First set of speakers almost done!! gimebakmybulits Full Range 2 30th April 2013 05:42 AM
first set of diy speakers y2kbugger Multi-Way 6 3rd June 2008 12:47 AM
Improving a set of speakers Code Multi-Way 10 24th January 2007 05:19 PM
WTB: 6.5 Woofer or Car Comp Set Pair Relax Swap Meet 6 15th October 2006 11:53 PM
