Construction Tips Construction techniques and tips
Befuddled with routing
Old 5th November 2013, 11:12 AM   #11
gootee is offline gootee  United States
Active usually allows you to have better-controlled impedances, so everything works better. High input impedance and low output impedance usually mean fewer unpleasant surprises, with easy-to-predict loads and levels, and, frequency responses. It's also just more flexible, making it easier to design with.
The electrolytic capacitors ARE the signal path: http://www.fullnet.com/~tomg/zoom3a_33kuF.jpg
Old 6th November 2013, 05:13 AM   #12
Hollow Root is offline Hollow Root  United States
That makes sense. One problem I notice with the setup that I put together is gain drops pretty significantly. The other thing is the eq has a tendency to become harsh and feedback. If you're interested you can hear how it sounds the way it is.
The Ghost Echo - Spring Reverb plus EQ Demo - YouTube
I'm going to keep working on it to get a better blend.
Befuddled with routingHide this!Advertise here!
Routing question... cyberspyder Multi-Way 6 21st February 2008 11:44 PM
Routing aluminium? EC8010 Everything Else 43 27th November 2007 12:31 AM
eagle routing djronbxs Everything Else 1 21st September 2007 06:45 PM
Routing signal yngwie Analog Line Level 0 17th June 2007 02:45 AM
Routing advice Glen1 Subwoofers 14 24th May 2007 04:02 PM
