Construction Tips Construction techniques and tips
Speaker repair disaster
Old 2nd November 2013, 12:50 PM   #1
Wimeden is offline Wimeden  United Kingdom
Default Speaker repair disaster
Hi
I am a bassist and have recently bought a secondhand tech 21 landmark bass amp, I noticed that there was constant distortion and on closer inspection I narrowed the sound down to coming from the speaker's dust cap. So probably rather stupidly I jumped straight into removing the dust cap with a scalpel and after finally getting the thing off, the speaker makes no sound at all. I am afraid I have cut cleanly through the cone it's self and cut the connection to the cone. Is there anything that can be done to salvage this mess? I'll go take some photo's so people can get a better look at what I have done...
Thankyou!
Old 2nd November 2013, 01:33 PM   #2
R.I.P.
Yes hopefully if its a paper cone.
Reattach the cone and dust cap carefully with wood glue.
Repair the cut tinsel leads.
rgds, sreten.
Old 2nd November 2013, 01:37 PM   #3
here are a couple of photos
Image View - TIS
Image View - TIS
Old 2nd November 2013, 02:28 PM   #4
R.I.P.
Hi, its very fixable by looks of it, rgds, sreten.
Old 2nd November 2013, 02:35 PM   #5
Thanks for the reply, I'm a bit new to all this, pretty sure it's a paper cone, how would I go about repairing the tinsel lead I am guessing that is the soldered on bit. If you can have a look at the pictures that would be great.
Old 2nd November 2013, 02:48 PM   #6
Brian Oshman is offline Brian Oshman  United States
Carefully scrape the tinsel leads to remove the insulation. Then solder them together. You will just have to blob some on bridging the two wires together then apply glue to the solder to hold it in place.
Old 2nd November 2013, 02:52 PM   #7
R.I.P.
I can't see the break that needs resoldering. Fix that first.
A small piece or 2 pieces of wire may help. * Make sure
everything on the cone is glued down after soldering.
To start rub wood glue along the line of damage on the back.
As the pulp softens push the line of damage back flat, don't try
to especially fix the cuts all the way through in one go. Let that dry.
2nd time round from the back redo the areas with a cut. Let that dry.
Clean up the front of the cone and the dust cap. Wood glue around
the dustcap and let it dry. Repeat the rear procedure on the front.
Finally wood glue around the dust cap and reattach it.
FWIW for anyone reading this rattling dust caps are best fixed by
running a line of glue around them, not trying to remove them.
rgds, sreten.
* You might need to scrape off some insulating laquer to get
a good joint to the voice coil wire, depends where it is cut.
Old 3rd November 2013, 11:44 PM   #8
Thanks everyone, I managed to find the cut tinsel lead and soldered it together, I have also glued the cone so fingers crossed.
Old 4th November 2013, 03:34 PM   #9
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Good news?
planet10 needs your help:
Let's help Ruth and Dave
Old 10th November 2013, 11:10 PM   #10
Ok so I managed to glue the speaker back together and solder the split wires but the speaker is still distorting like before.. Think maybe I was too hasty in presuming it was the dust cap I think all I was doing was dampening the speaker when I put my hand on it rather that fixing the distortion.. I've run the head of the amp through other speakers and it sounds like a completely different amp, the damaged speaker goes real loud but the crossover between clean and distortion seems completely invisible so even at low volumes it's distorted. I've done a few tests I know on the speaker ie pushing the cone in and out and it sounds clean, no scratchy sounds and I've checked for any tears in the cone (and fixed the ones I caused) are there any other tests I can do to know that it is blown? I don't want to buy a new speaker unless I really have to and it seems strange that there is no visible damage, big bass speakers like this should be able to take quite a pounding..
Thankyou!
Speaker repair disasterHide this!Advertise here!
Nearly a DIY disaster activexp Multi-Way 3 30th November 2010 01:59 AM
AM I Planning for disaster?? birdyman Pass Labs 12 2nd October 2010 01:59 AM
Disaster NEED HELP PLS! leander Solid State 11 19th September 2005 07:59 PM
Near Disaster! Bikeman Everything Else 1 4th September 2003 06:18 AM
Saving a Speaker Design Disaster, Can You Help? surf,sun&sound Multi-Way 10 29th October 2001 06:30 AM
