Construction Tips Construction techniques and tips
Heatsinks
Heatsinks
Old 27th October 2013, 08:26 PM   #61
sofaspud is offline sofaspud  United States
sofaspud's Avatar
Sounds good to me. I would in any case use a heatsink which, by itself, is a little over-rated for the task, and apply heatsink grease to any mating surfaces.
I meant ''by far best'' in a practical sense, not familiar with examples of vacuum insulator use in real life.
Ah, I was taking it literally. Like a dewar or Thermos brand bottle.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 27th October 2013, 09:49 PM   #62
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Good one, stupid me even has a couple of fancy SIGG specimens.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 28th October 2013, 05:17 AM   #63
Andersonix is offline Andersonix  Sweden
Andersonix's Avatar
Heatsinks
By mounting the flat (rear) part of the hs against the chassis, you are insulating the flat part of the hs with the steel and losing that much hs area that could be used for cooling. Can you offset the hs with some spacers to open a gap in there?
Old 28th October 2013, 07:54 AM   #64
ticktock is offline ticktock  Scotland
ticktock's Avatar
You don't want to cool the heatsink, you want to cool hot running devices.
The heatsink dissipating heat into the chassis is more than questionable.
Again, I do believe isolating the heatsink from the chassis is a good idea.
thanks
Blaue Leuchtdioden machen bl÷d. (hb)
sent from NSA monitored device
Old 28th October 2013, 12:16 PM   #65
Which is what Goldmund has been doing for a long time.
If the spacer thickness is sized accurately, the stack effect may even help to cool the chassis.
Old 28th October 2013, 11:06 PM   #66
KatieandDad is online now KatieandDad  United Kingdom
KatieandDad's Avatar
Well, I've had one of the F5 modules running for about ten minutes, it's getting late so I'll continue in the morning, the heatsink didn't get above cold.
I'm sure it will warm up after time but the initial indications are that they should be sufficient.
Old 3rd November 2013, 05:09 PM   #67
With both of the F5 modules working the heatsinks are more than adequate, after over two hours neither are more than warm.
http://www.diyaudio.com/forums/pass-...ml#post3690005
HeatsinksHide this!Advertise here!
Heatsinks Andrew Covell Solid State 3 22nd January 2011 09:30 AM
Intel CPU heatsinks as power output transistor heatsinks? deltavektor Solid State 4 29th November 2009 01:47 PM
heatsinks, heatsinks..... bigpanda Parts 4 26th June 2005 08:42 AM
Heatsinks? tze-hao yen Pass Labs 3 12th March 2005 02:58 AM
Heatsinks woody Parts 17 18th August 2002 02:04 AM
