Construction Tips Construction techniques and tips
Heatsinks
Heatsinks
Old 16th October 2013, 01:11 AM   #21
sippy is online now sippy  United Kingdom
OR.......just look at the pictures of Pass amps that have been built, funny how they follow a certain trend re mounting of output devices!
Old 16th October 2013, 01:46 AM   #22
R.I.P.
I'm out of here before before it gets too whatever. You don't
need to mount output devices directly to external heatsinks
and mounting via steel walls doesn't make much difference.
rgds,sreten
Old 16th October 2013, 07:36 AM   #23
sofaspud is offline sofaspud  United States
sofaspud's Avatar
Q = K (A/L) ΔT
where
Q = heat flow
K = thermal conductivity
A = cross section of heat flow path
L = path length
ΔT = temperature drop along path of length, L
It looks to me like the difference is dominated by K.
But I've been wrong before, and survived intact.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 16th October 2013, 09:51 AM   #24
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
Originally Posted by Andersonix View Post
Katie: Can you show us pics of the heat sinks and the steel chassis you intend to use, so we can offer some practical suggestions?
I'm still waiting for the chassis to arrive but its a 4U steel 19" rack case.
Old 16th October 2013, 01:46 PM   #25
CanAm Man is offline CanAm Man  United States
Katie and dad--I forgeo you were the original posters on this thread! Sorry.....
I'd recommend you look at the Pass First Watt amps, and those built by competent DIY'ers. All good designs mount the output semi's directly on the heatsink. Use mica + grease, or kerafoil, for insulators (they insulate the MOSFETs electrically, but are good thermal conductors). Use the largest heatsinks practical (I used Conrads, from Australia). If you MUST use a steel case, cut holes large enough to still mount the semi directly to the heatsink (i.e., don't try to sandwich the steel chassis/case between the semi and heatsink).
If you still have doubts, ask the same question on the Pass forum, indicating you are building an F5. I'm certain you'll get get a flood of consistent feedback--and that it will underscore what I'm saying.
Old 16th October 2013, 01:50 PM   #26
Originally Posted by sofaspud View Post
Q = K (A/L) ΔT
where
Q = heat flow
L = path length
Sofaspud..... Fear not. You're right on the mark. And for any continued "doubters", the thermal conductivity coefficients for varous materials are readily available on the internet. In a quick nutshell: diamond is about the best (but I don't think you'll find many audio chassis made of it....!); copper is very good, aluminum is good, and steel.....is steel.
Old 17th October 2013, 12:50 PM   #27
bear is offline bear
expert in tautology
bear's Avatar
Heatsinks
sreten must have been nipping at the "rat cheese" perhaps?
1) going through more layers *must* decrease thermal conductivity
2) steel sheet metal chassis are *non-flat* further decreasing the thermal conductivity
3) steel as has been noted several times before is a *less good* thermal conductor
4) the tabs on these plastic pak Mosfets, NOT TO-3 style transistors, are small enough and as such require the best possible thermal path
5) Most of the tabs (back surface) on the plastic paks are plated copper not steel afaik, or worse case steel plated with copper then cadnium (probably cadnium)
6) connected to a steel plate (or sheet metal) the ability of the aluminum heatsink's flat back surface to shed heat is substantially reduced (the case where there are holes punched for the devices, for example) which somewhat reduces the total ability of the heatsink to shed heat, upping the temperature rise.
6a) The lower the conductivity of the thermal path, the higher the internal temperature of the device and bonding wires can reach, for example on peak current draw or in the case of Class A devices, on turn-on. Which is why heatsinks are needed in the first place...
7) Physics: hotter devices have lower SOA.
PS, for some RF type amps a copper "spreader plate" is required because even a direct connection to the aluminum isn't sufficient.
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 17th October 2013, 08:15 PM   #28
sofaspud's Avatar
It would be nice to see some numbers that substantiate this. Can the heatsink shed heat into the air easier than into the steel?
edit: IOW... Without looking, I think the thermal conductivity of air is worse than steel, but ΔT may begin to dominate the equation giving air the advantage.
Old 17th October 2013, 08:28 PM   #29
I never thought that it would get this complicated. I'm going to cut some holes in the case and mount the devices directly onto the aluminium.
There's more to worry about than just the steel, how about the paint ? It all adds up to increase the transfer resistance.
Old 17th October 2013, 08:32 PM   #30
Andrew Eckhardt is offline Andrew Eckhardt  United States
The surface to air resistance is practically unchanged for the part of the heatsink covered by the steel chassis even with high air flow, so long as the junction between them is greased. Don't worry about that. One of the problems though, is it does have to be greased all over for that, and very flat, and clamped without causing distortion. In the case of sinking a power device Through the chassis and into the aluminum extrusion, you need Much lower resistance.. to the point of necessarily removing the finish (because it's a good thermal resistor) quite far around the device. If it's epoxy or powder coat, that'll suck. It's not that the steel gives a useful "spreading" effect, it's resistance is much too high for that, but the thickness of the finish will cause distortion and voids around the edges, so it has to go away and far. Getting an even squash over the double junction with no distortion would take more and better distributed pressure than you can get by a single screw through the tab and proper torque. In the end, the extra junction, even if everthing is attented to with extreme care, makes it a loser by comparison. What's to debate?
HeatsinksHide this!Advertise here!
Heatsinks Andrew Covell Solid State 3 22nd January 2011 09:30 AM
Intel CPU heatsinks as power output transistor heatsinks? deltavektor Solid State 4 29th November 2009 01:47 PM
heatsinks, heatsinks..... bigpanda Parts 4 26th June 2005 08:42 AM
Heatsinks? tze-hao yen Pass Labs 3 12th March 2005 02:58 AM
Heatsinks woody Parts 17 18th August 2002 02:04 AM
