Cleaning up heatsinks... - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 7th October 2013, 06:11 PM   #1
mortron is offline mortron  Canada
Default Cleaning up heatsinks...
My heatsinksusa pieces are here, and before using them I wanted to deburr the fin edges and clean them up.
My biggest question I have yet to find an answer for is how do I clean up the cut edges of extruded heatsink. There are some grinding marks and swirls. Would I use a brushing or lapping technique to sand them smooth? Here is a photo showing the swirls and one of the ground spots.
Old 7th October 2013, 06:43 PM   #2
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
I have used a fine file
if you know how to use one
or else it might get tricky
or try with very fine emery cloth on a wooden paint paddle, paint mixing stick, or whatever you call it
btw, I suppose dressing edges only
sometimes we know very little, and sometimes we know too much
Old 7th October 2013, 09:39 PM   #3
Andersonix's Avatar
There are different grades of Scotch-brite type abrasives to try for light scratches.
Old 7th October 2013, 09:56 PM   #4
expert in tautology
bear's Avatar
For what you show in the image, the saw seems to have gouged a bit, I'd first inquire back to the supplier. Assuming they say that nothing is wrong, I'd try the following idea.
On a known flat surface, like a piece of glass (thick plate glass) or on another flat surface I'd stick on a full sheet of ALO and then rub the entire heatsink across that big flat surface.
WORK WET.
Water or oil.
Best to use "wet or dry" paper. Water on the back side of the paper may give enough adhesion, but if not glue stick, rubber cement, or the stuff they sell to put abrasive shapes to vibrational sanders will work. (non-permanent goop) Thin double stick tape might be ok, but even that few thousandths of an inch will make the surface non-flat. But you could use two strips on along parallel edges and run the work between them, on the flat.
Start with a fairly coarse grit and work back to a fine grit.
If you are going to get them anodized, the anodize process will etch all of the thin fine edges on the fins, where they were cut or sanded.
I'd not use a file, since it is difficult to control and usually results in an uneven result.
If ur not going to have the pieces anodized, then I'd suggest an bath in lye for a while. This will impart a uniform finish on the piece. Try with some scrap to see the results.
EYE PROTECTION AND GLOVES ARE MANDATORY WHEN USING LYE OR ACIDS
Some Alkaline "degreasers" and "cleaners" will act as "brighteners" after a bath in the the lye. They also work to clean the work after using tapping/cutting fluids and filing/sanding.
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 14th October 2013, 03:07 AM   #5
Thanks this is this kind of information I am after. I will work with what you gave me. I got them ages ago and have been sitting, and was part of a group buy. Lesson learned. I just want to get to work on these two for now. I also have another four more in 8 or 10" height (its late) for an F5T, so I may as well practice on this one
Intel CPU heatsinks as power output transistor heatsinks? deltavektor Solid State 4 29th November 2009 01:47 PM
Cleaning up jackinnj Construction Tips 5 22nd August 2009 12:37 AM
Cleaning cones sangram Multi-Way 1 30th August 2006 11:20 PM
Record cleaning? Tazzy Analogue Source 4 2nd September 2005 12:59 AM
Cleaning an Amplifier? mhk62 Solid State 6 7th December 2004 06:24 PM
Copyright 1999-2017 diyAudio
