Construction Tips Construction techniques and tips
105v trigger.
105v trigger.
Old 16th September 2013, 02:11 PM   #11
back is offline back  Greece
it didn't work.when the inverter disconnected the full voltage passed through the relay and the zener and the soldering melt.
i guess i need a comparator.
Old 16th September 2013, 02:19 PM   #12
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Remember that solar cells are current sources, not voltage. then it's output impedance is high.
The equivalent model is escentially a current source in // to a diode join.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
105v trigger.Hide this!Advertise here!
12v trigger olh Class D 4 27th July 2012 12:14 AM
Trigger for Amplifier Lovan Solid State 12 22nd September 2008 06:43 AM
12v UPS relays Trigger, 1 ~ 11v no trigger jacquesl Power Supplies 5 28th August 2007 05:30 PM
What is a trigger tube used for? Gunders Tubes / Valves 4 30th March 2003 01:53 AM
