Construction Tips Construction techniques and tips
Speakers on bookshelf need to tilt down
Old 2nd September 2013, 01:19 AM   #1
toxic ingestion is offline toxic ingestion  United States
Default Speakers on bookshelf need to tilt down
I desire to set two bookshelf speakers on a bookshelf above my desk, tilting down, directed at me. I can separate them by about 9 or 10 feet without a problem, and they will be about 5 feet above me, vertically. But I can't find a bracket that would mount on the top of the bookcase (above and behind trim) on which I could mount a speaker AND allow the speaker to be angled down by 30 degrees or so. I may need to build something, but wondered if anyone was aware of commercial hardware that I may have missed. Thanks.
Old 2nd September 2013, 07:10 AM   #2
Enzo is offline Enzo  United States
How about one that mounts to the wall instead. Those come in all shapes and sizes.
And for that matter, one could probably mount one to the shelf instead of the wall.
I would chose a model that has braces around the speaker cab instead of just screwing it to the cabinet wood. You won;t want the things falling on your head if the screws pull out or the wood breaks.
Old 2nd September 2013, 03:45 PM   #3
Yes, mounting to the wall will be my last option, but the wall sits back quite a ways from the book shelves. If need be, I can construct a wooden base tilted forward with a front ledge to prevent the speaker from sliding or falling forward that will simply sit on top the book shelf. I was hoping that a company somehwere had already offered a solution to this problem. Of note, I have seen something similar to what I need that offers a 10 degree tilt, but not the 30 degrees or so that I need.
Old 3rd September 2013, 04:44 PM   #4
chrisb is offline chrisb
cut some wooden wedges on band saw and velcro tape to keep from slipping?
sounds like they'd be sitting behind the front trim on the bookcase, so they wouldn't even need to be particularly pretty, no screw holes anywhere, and easily moveable
kinda burnt out - taking a break
Old 3rd September 2013, 07:00 PM   #5
dangus is offline dangus  Canada
Buy a couple of angle braces (not the reinforced shelf brackets) and bend them? Bolt two braces together?
Old 3rd September 2013, 11:37 PM   #6
Both of you share my general thoughts. You are correct these will sit up on top, behind the trim, and the wooden, tilted bases I would construct would be below the trim level. I will use some angled braces or a wooden ledge at the front of the angled base to hold the speaker back so it doesn't slide or fall forward. Perhaps one of you should manufacture these and then retire!
Speakers on bookshelf need to tilt downHide this!Advertise here!
Which speakers to buy for bookshelf speakers timkoh Full Range 21 5th February 2015 10:52 PM
Bookshelf speakers unknownuser200 Multi-Way 20 21st January 2012 06:09 PM
Bookshelf Speakers Sammich Multi-Way 5 29th June 2007 08:01 AM
bookshelf speakers Mike Gergen Multi-Way 6 30th April 2007 12:19 PM
Bookshelf Speakers avguy Multi-Way 32 10th November 2003 10:36 AM
Copyright ©1999-2017 diyAudio
