Construction Tips Construction techniques and tips
Cutting sheet metal
Cutting sheet metal
Old 25th August 2013, 02:59 PM   #11
DEQ+TheEnd is offline DEQ+TheEnd  Norway
DEQ+TheEnd's Avatar
Originally Posted by AVWERK View Post
Or go to Harbor Freight and get the cheap right angle grinder with a thin 4" cut off wheel that will butter right thru it.
hmmm... smaller blade might flex less. I used a 125mm (5") disc.
Experience have so far with the angel grinder is that multiple passes work better than one single cut. Maybe I could try to hing the angle grinder under the table. And then use a spring to apply pressure on the angle grinder.
Old 25th August 2013, 03:18 PM   #12
R.I.P.
I wish I had one (or even known about it) for cutting my cast iron gutters and downpipes.
regards Andrew T.
Old 26th August 2013, 04:29 AM   #13
dchisholm is offline dchisholm  United States
dchisholm's Avatar
Originally Posted by ODougbo View Post
Originally Posted by zane View Post
I need one of these!!
One question that comes to mind is how to keep the powdered metal and small chips away from the bearings of the circular saw. If you do a lot of metal cutting with it there may be a case for mounting the "rotary hacksaw" blade in a cheap saw and accept the fact that you'll discard the saw periodically (possibly while the blade is still quite serviceable.)
Dale
Old 30th August 2013, 07:22 AM   #14
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
Cutting sheet metal
@DEQ+TheEnd ,
you can use a straight edge piece of wood or metal to cut a straight line....
line it up in parallel to the target line cut and guide the edge of the jigsaw with it...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 30th August 2013, 07:44 AM   #15
DEQ+TheEnd's Avatar
Originally Posted by AJT View Post
@DEQ+TheEnd ,
Well, that was my hope to. You can see the result from that exercise on the top picture. The saw blade seems to have a mind of it's own. I'll say it will not pass a drunk test
Old 30th August 2013, 08:12 AM   #16
TonyTecson's Avatar
Cutting sheet metal
well in that case look for a shop that has this guillotine shear, that should work...
Old 30th August 2013, 08:30 AM   #17
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
I tend to cheat. I go to our local industrial estate and in the engineering departments the guys there will cut my sheet metal on the guillotine for the price of a beer or two.
Saves all the hassle and wasted time ... and sticking plasters on my finger ends!
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 30th August 2013, 08:42 AM   #18
DEQ+TheEnd's Avatar
He he . Just tried that this week. One sheet of 2mm aluminum 1x2m 95$ + 25% tax. Work cost cutting this to my specifications (simple strait cuts) estimated to $400 + 25% tax.
Next time I buy the bear first, then I ask
Old 30th August 2013, 09:07 AM   #19
WOW!
For that sort of cost you could buy a second hand guillotine and do it yourself in the garage!
See fleabay Sheet metal guillotine
That was within 5seconds of looking but the links don't work!. There are loads to choose from.
Last edited by JonSnell Electronic; 30th August 2013 at 09:08 AM. Reason: Removed links that don't work in this screen
Old 30th August 2013, 09:26 AM   #20
TonyTecson's Avatar
Cutting sheet metal
that's highway robbery.... $400 + 25% tax
i could build a very good tube amp with that money...
Cutting sheet metalHide this!Advertise here!
Cutting openings in metal panels akis Equipment & Tools 19 28th September 2013 08:37 AM
Sheet Metal Shear! dirkwright Equipment & Tools 10 26th January 2012 03:24 AM
Sheet metal cooling Skorpio Pass Labs 1 10th May 2008 12:49 PM
Sheet Metal Gauge kafka007 Tubes / Valves 10 15th November 2006 01:40 AM
cutting metal/plastic sheets ?? kambule Everything Else 0 30th June 2006 10:58 PM
