Inductor Computation - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 2nd August 2013, 03:50 AM   #1
Default Inductor Computation
Hello There,
Could Anyone please show me how to make inductors and computations?
Old 2nd August 2013, 05:04 AM   #2
KatieandDad's Avatar
Could you please expand on what you are trying to make ? There are inductors and there are INDUCTORS.
The requirements of a crossover inductor are very different to a choke for a power supply for example.
Old 2nd August 2013, 05:11 AM   #3
im sorry, but its air core inductor for power amp output. thanks
Old 2nd August 2013, 12:24 PM   #4
Try Googling - Wheeler's Formula.
Old 7th August 2013, 11:55 AM   #5
Send a message via Yahoo to johnthetweeker
I used this formula for air-core coils from the 1936 Edition of Electrical Engineers' Handbook (Pender Mcilwain). A scan of the page is attached below.
If you have a way to run GWBasic in your PC you can use the following BASIC program which I wrote in early nineties to compute the number of turns, length and weight of the copper wire you need. Fairly accurate. (You have to input the diameter of the wire in inches, taken from a SWG or AWG table). Eg., SWG-18 is 0.048 inches dia., which is the default if you don't input a value.
300 INPUT "INDUCTANCE (MICRO H)?", LR
310 INPUT "Wire diameter(inches)?",D
320 IF D=0 THEN D=.048: PRINT "WIRE 18 SWG (DIA=.048 INCH)"
330 NL=1
340 REM D1=DIA OF FORMER
350 PRINT "DIAMETER OF FORMER, IN INCHES (DEFAULT: 1 INCH.)";
360 INPUT D1
365 IF D1=0 THEN D1=1
370 REM B=LENGTH OF WINDING
380 PRINT "LENGTH OF COIL, IN INCHES (DEFAULT: 1 INCH.)";
390 INPUT B
395 IF B=0 THEN B=1
400 R=D1/2
410 REM A=MEAN RADIUS OF COIL
420 A=R+((NL*D)/2)
430 REM c=depth of winding
440 C=NL*D
450 N=NL*(1/(D+.001))*B
460 L=(.8*(A^2)*(N^2))/((6*A)+(9*B)+(10*C))
470 GOTO 620
480 NL=NL+1
490 IF L>=LR GOTO 510
500 GOTO 400
510 N1=SQR((LR*((6*A)+(9*B)+(10*C)))/(.8*(A^2)))
520 PRINT INT(N1+.5);"turns"
530 PRINT"depth of winding=";C;"inch
540 PRINT "length of wire=";TL;" inches"
550 REM METRIC CONV.
560 RM=(D/2)*2.54
570 TLM=TL*2.54
580 VOLM=PI*(RM^2)*TLM
585 REM Specific gravity of copper=8.92
590 WC=VOLM*8.92
600 PRINT "weight of copper=";WC;"gms"
610 END
620 REM
630 PI=3.1416
640 R1 = R +(D*NL)-(D/2)
650 LC= 2*PI*R1
660 LL=LC*(B/D)
670 TL= TL +LL
680 GOTO 480
John
John (not the baptist)
Here is the Computation of EI core Transformer Philippines Base tranqspogi Power Supplies 9 12th February 2015 08:32 AM
Copper coil inductor vs. round core inductor tomchaoda Pass Labs 7 21st September 2011 04:42 AM
Quantum computation abraxalito The Lounge 0 14th May 2011 12:41 AM
air core inductor vs. iron core inductor WBS Planars & Exotics 5 7th May 2007 11:02 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
