Construction Tips Construction techniques and tips
Simple enclosures for valve projects
Old 1st August 2013, 08:34 AM   #1
smagrath is offline smagrath  Australia
Default Simple enclosures for valve projects
My first post here.
I'm after thoughts on simple DIY enclosures (ie box) for my DIY valve amp projects. This also includes chassis design and construction.
The idea is that I can run the prototype for a few days (weeks/months), make changes if needed, new additions... resolve the design before commiting to a final build.
I can do the high quality woodworking when I need to but there are many prototype / research projects I'd like to where I don't want to cut wood or bend aluminium, or... I think you get it
I'm thinking simple hobby screw construction of plates and channelised aluminium/brass struts (if that exists) on perhaps a mesh.
Is anyone aware of an internet-based supplier of this type of thing?
How do you do your valve/HV prototyping?
Old 1st August 2013, 02:51 PM   #2
DF96 is offline DF96  England
Unless your prototype debugging is likely to result in a radical redesign (in which case it could be argued that you didn't think hard enough) the major components are unlikely to change. I make the chassis for the final build, but ensure that there are plenty of spare tag strips for extra components.
Old 1st August 2013, 04:37 PM   #3
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
For a prototype, I use a rear side of a protoboard PCB, look at this fotos.
I expect this can solve easily the question :-D
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 2nd August 2013, 07:26 AM   #4
Thanks Osvaldo for the photos - I see what you mean, though I was somewhat distracted/envious with the size of your power transformer for a while :-)
Whilst that will work in the shed I was looking for some enclosures as well - I may have found most of the components I want:
McJING Tools Online
The T-Track system and the insert rivets may be sufficient for my needs for mocking up some prototypes...
Old 2nd August 2013, 12:30 PM   #5
This power transformer was winded for myself several years ago. I was working in a B&W tube TV when the original catched fire. Then, I was at secondary school (Here called ENET: Escuela Nacional de Educación Técnica, or National school of technicals), when I was at 4Th year (6 in total). It is a lamination 60 and gives 6.3V @10Amper, 220V+220V @250mA and a 6.3V@1A for the EZ80 rectifier. But the final project I'll use self-hand wired toroidal transformers.
Finally, the amplifier surely will be like the AM regenerative receiver at the last 3 photos: chassis made of brass, and components in a card.
Simple enclosures for valve projectsHide this!Advertise here!
Custom enclosures / cases for your DIY projects richardkrol Vendor's Bazaar 82 19th April 2014 11:24 AM
DC/DC stepup for valve projects SBD Tubes / Valves 8 12th May 2013 09:30 PM
Simple Valve Preamplifier mangrovejack Tubes / Valves 15 7th April 2008 12:34 AM
enclosures for diy amp projects ToAjit2Quit Solid State 4 26th December 2005 08:32 PM
simple valve preamp mr l Tubes / Valves 2 21st October 2004 01:10 PM
