How do I replace spring loaded door magnet? - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 24th July 2013, 08:26 AM   #1
Default How do I replace spring loaded door magnet?
Hello, I'm not quite sure what it's called so I included a photo.
I have a hi-fi system cabinet that has this spring loaded magnet for the door but the trouble is that the spring is too weak to propel the door away. I'm assuming that short of something like filing off some of the magnet, there's really nothing I can do about it but I can't see how it's attached.
When there aren't any screws visible, how are these devices usually attached? It isn't common practice to glue them in, is it?
Thank you in advance and I apologize for my ignorance.
Old 25th July 2013, 01:18 AM   #2
Andersonix's Avatar
Probably pressed in, relying on barbs on the plastic housing to keep it in, but might also be glued...
My guess is the spring is still as designed, but that there's friction at the hinges (try oil?) preventing the door from opening as you expect...
Old 25th July 2013, 02:11 AM   #3
Thanks for the suggestion but I'm not sure that's it because when I move the door it moves very smoothly at the touch of a finger.
Well, worse comes to worse, I might have to break it out, no big deal.
Old 25th July 2013, 03:45 AM   #4
Andersonix's Avatar
Maybe it needs that special touch? Or prop it up a tiny bit in the back to get a gravity assist...
Spring Clip /Spring Clamp removal video bigpun4fubu Car Audio 9 15th December 2014 05:55 AM
Spring loaded Dust Cover Hinges for homebrew DIY Record Players Turntables tiefbassuebertr Analogue Source 4 28th August 2013 04:36 PM
Looking for a Good Sliding Door track and door for Delco/Pioneer 12 disc cd changer wascapsfan Parts 0 24th June 2012 01:23 AM
Replace old spring-loaded amp speaker connectors with binding posts or speakon tlparker Parts 20 17th February 2007 07:32 PM
Spring Loaded Terminal Post For Fire works Firing Rail ddpode Parts 2 4th July 2004 01:16 AM
Copyright 1999-2017 diyAudio
