Construction Tips Construction techniques and tips
How to get a high gloss black finish (near piano black)
Old 5th July 2013, 03:46 PM   #11
WagBoss is offline WagBoss  Canada
Originally Posted by WagBoss View Post
for sealing the mdf, I have read a lot that shellac is the best. Which one should I use? Shellacs | Interior Stains & Finishes | Paint | Décor | Home Depot Canada
Is there something better then shellac?
can anyone answer this please?
in regards to taking this to a boat builder, I'm not really interested in that, this is a DIY forum :P
Old 5th July 2013, 06:34 PM   #12
6speed is offline 6speed  United States
6speed's Avatar
I'm not a wood working expert. However, as I understand shellac is referred to as being either "shellac" or "dewaxed shellac". The "dewaxed shellac" is the version that is considered the universal sealer / everything sticks to it / it sticks to everything variety. I would read the label carefully to see if it is listed as being "dewaxed", if it does not say then I would assume it contains some wax and you might want to look for a different one since you plan to paint over it.
Old 5th July 2013, 10:05 PM   #13
chrisb is offline chrisb
Is there something "better than", or at least alternative to shellac for sealing MDF - yes, certainly if you're not worried about bleed through of stains, and planning on building several color / top coats - ranging from the consumer products available at the likes of Rona, Home Depot, Home Hardware, etc. to industrial products for the commercial cabinetry / woodworking trades, available through regional distributors.
When you mix the phrases "high gloss" and "piano black paint" in the same thread, I think of a finish with depth and durability. You'll probably want to look at the polyurethanes, tinted lacquers or varnishes, as opposed to acrylics, latex, or even marine grade alkyd enamels which are still available in some locations.
Exactly where in Canada are you located? That can affect access to the commercial grade products.
There's certainly no reason not to spray the sealer/primer, color and top coats, but you will want to invest in a decent gun, water trap/filter for a standard compressor based system, or a turbine powered HVLP system. Be prepared to spend a few hours of practice to get it right, particularly if wrapping around curved profile edges, at least a few coats to build depth, and lots of polishing / buffing of the final couple of coats. Altogether the painting can take much more time than the fabrication.
kinda burnt out - taking a break
Old 5th July 2013, 11:05 PM   #14
wirewiggler is offline wirewiggler  United States
For sure my deepest looking finishes have been with lacquer, the interesting thing about it is the coats all melt into each other to become one layer. This posed a problem for me one time I let a speaker I was working on outside to dry and the sun hit part of it and it blistered. To fix it I had to sand all of it off. The finish is quite stunning, however care must be taken as it is never is completely cured and will react with things placed on it. Now some of the new water-based urethanes made today are pretty impressive, easy to work with , easy to clean, and produce a durable finish. The other thing about MDF for some reason my joint lines never completely go away, since I veneer about everything I build it has not been a problem but I am sure there is some trick.
Bill
Old 6th July 2013, 10:06 AM   #15
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Ah the old joint showing problem. Difficult to eliminate completely, but can be very much minimised by keeping the wood in the house for a couple of weeks or more prior to glueing, the use of a rigid glue such as urea formaldehyde (definitely not PVA) and better quality MDF - deep router grade, or moisture resistant at a push.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 8th July 2013, 06:10 PM   #16
Ok based on what I have access to basically my only option was high gloss black enamel or high gloss black lacquer. I went with the lacquer. Rust-Oleum Specialty | Lacquer - Gloss Black | Home Depot Canada
What should I seal the MDF with? The guys at home depot had no idea... lol. Should I just use an oil based primer, or should I use this? Zinsser | Shellac -Clear -473Ml | Home Depot Canada
It does not say if it is dewaxed or not. Since it doesn't say dewaxed does this mean it has some wax?
Any suggestions on what grits of sandpaper to get to do each coat?
Old 8th July 2013, 06:11 PM   #17
Bill
What did you put under the black lacquer? Any sealer or primer? Did you put a top coat of a clear high gloss, or did you just sand the lacquer and it gave you the high gloss finish that you wanted?
Old 9th July 2013, 01:56 PM   #18
Ok I have found this zinsser bin primer sealer Zinsser | Zinnser Bin Primer -946Ml | Home Depot Canada
Would this work good to seal the mdf before I put on the black lacquer? Is it ok to paint this on with a brush?
I could also use the same stuff but in a spray can, it's a bit more money http://www.homedepot.ca/product/369g...r-spray/978744
Old 9th July 2013, 02:44 PM   #19
6speed's Avatar
I could also use the same stuff but in a spray can, it's a bit more money Zinsser | 369g BIN Primer Sealer Spray | Home Depot Canada
IMHO, I would say that's what you want. Shellac goes on smooth with a good fine brush. Be sure to grab some denatured alcohol to clean your brush and thin the shellac to a workable consistency that you like if needed, it is usually pretty heavy in the can.
One thing I learned working with shellac in the past is it dries really fast as compared to poly, it comes back to life with denatured alcohol or with more shellac but I found I needed to work with small batches and not "mess around".
Old 9th July 2013, 06:24 PM   #20
Did it Himself
I think you were right to go for lacquer rather than enamel. You would have struggled flatting and polishing the enamel.
Zinsser BIN is a good primer/sealer if a touch expensive. Well it is over here anyway. Without a spraygun setup I would say brush or roller it as you will go through spray cans too fast and this will cost too much.
Take your time and you should have a good result.
How to get a high gloss black finish (near piano black)Hide this!Advertise here!
piano black or other high gloss finishes on MDF mondogenerator Construction Tips 20 31st May 2014 04:04 AM
Ideas For Getting Piano Black Finish 2MuchRiceMakesMeSick Construction Tips 8 7th February 2012 10:27 AM
FS: Dayton Speaker Cabinets - Gloss Piano Black uzernaam Swap Meet 2 8th December 2010 12:20 AM
Applying piano black finish help Toast_Master Subwoofers 15 28th May 2006 07:48 AM
Copyright ©1999-2017 diyAudio
