How to install a LCD on a frontplate ? - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 24th June 2013, 08:58 PM   #1
Default How to install a LCD on a frontplate ?
Hi Friends,
My current project will have a LCD display in the front plate of the cabinet.
So I plan to "drill" a rectangular hole in the frontplate, matching the exact LCD dimensions (+0.5mm to simplify the install).
I would like to know your recommandation on how to fix it on the front plate: what do you use to keep it in place ?
A photo would be appreciated !
Old 28th June 2013, 04:45 PM   #2
SRMcGee is offline SRMcGee  United States
SRMcGee's Avatar
Nounours18200:
I've used two different methods for mounting a display. For my Aikido preamp, the display was mounted on a frame built from aluminum angle stock and standoffs; see the first two photos below. I used this approach because of its simplicity. For my Aleph P 1.7 preamp, the display was mounted directly on the rear face of the 10mm thick front panel. Front Panel Express was used on this project, and their services made this approach very easy. The last two photos should help.
Good luck with your project!
Scott
Good decisions are derived from experience; experience is derived from bad decisions.
Old 29th June 2013, 02:19 AM   #3
SRMcGee very very nice pieces of equipment you have there. Can I ask what the lcd's aredisplaying.
Once again......sweet.
John
Old 29th June 2013, 07:31 AM   #4
KMossman's Avatar
Send a message via Yahoo to KMossman Send a message via Skype™ to KMossman
Do you intend to have it flush with the exterior surface?
It might sound awful, but I would use hot glue - rough up the Al so it sticks better - start with spots of glue at the corners then a stream around it
Getting back into business, though non-audio related. Have excellent contacts for NEW [OEM] Russian and Chinese tubes. Custom chassis, and parts [MOQ applies]
Old 30th June 2013, 07:28 PM   #5
Thanks SRMcGee ! Very useful information...
I have 2 additioinal questions:
A-/.where have you bought the 6 switches (Power, Source, Monitor,...) that we see on your PASS frontplate ? I also have to use similar switches on my project, and I do not know where to buy them. I am also looking for other formfactors, such as "push buttons"", but your would already be a convenient solution !
B-/.you say that you have used FrontPanel for your Pass project, but have they perform the required Tapping, necessary to screw the printed circuit with the frontplate ?
Thank you very much !
Old 30th June 2013, 08:55 PM   #6
SRMcGee's Avatar
vasques101uk:
The displays for both preamps were purchased, along with the attenuators, source selectors and the necessary control boards from Mikkel Simonsen at dantimax. The Aleph P 1.7 display is showing the following:
-20dB -20dB
Compact Disc
Nounours18200:
It may take me a day or so to find the BOM for that preamp, but I'll let you know what switch I used. All of the switches are mounted on a 3 mm aluminum strip, and the strip is bolted to the front panel. Front Panel Express drilled and tapped the necessary mounting holes on the rear of that front panel to my specification. It was necessary to have slightly enlarged holes on the rear side of the front panel, to account for the switches' protrusion off the aluminum strip.
And yes, FPE does a great job -- if you can design it, they seem capable of machining it (though at times at quite a significant cost).
Scott
Old 1st July 2013, 01:46 PM   #7
SRMcGee's Avatar
Nounours18200:
It seems the switches I used are now obsolete, but their data sheet may be helpful in locating a suitable replacement: 10TA445 Mountain Switch | Mouser
Scott
My new install Cal Weldon Car Audio 5 11th March 2011 07:18 AM
Help with Clock Install!! .45 GAP Digital Source 1 26th March 2009 06:34 PM
New Sub And Amp Install Staticjeep Car Audio 0 2nd June 2006 07:21 PM
How Not To Install A System! nickg239 Car Audio 17 29th June 2005 09:24 PM
new install maxiboy Car Audio 6 26th June 2005 11:06 PM
Copyright 1999-2017 diyAudio
