diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Construction Tips (http://www.diyaudio.com/forums/construction-tips/)
-   -   Fun selector LED layout.. (http://www.diyaudio.com/forums/construction-tips/237737-fun-selector-led-layout.html)
M Gregg 16th June 2013 03:40 PM
1 Attachment(s)
OK this is for fun..
How do you wire a rotary selector switch using a bridge rectifier and a single diode so that 5 leds light to show the position of the switch ie one led shows position 1, two leds show position 2..the format is in the picture..(The dots show the leds that should be on in each position)..
I have the answer and will post it shortly..:D
M. Gregg
Andersonix 16th June 2013 08:36 PM
I try to keep any indicator lights to a minimum (and also keep them in a low energy, low glare red color -- as opposed to blue). Do you actually want 5 LEDs to be on at any one time? And will you be able to discern 4 lights on from 5 at the listening position?
dangus 17th June 2013 01:29 AM
A diode matrix is the answer. Consider using a 7-segment display to display the input number directly. One segment is used by all the digits, so can be wired permanently on, 2 & 3 have 3 more segments in common, so that can save a couple more diodes. How about a Nixie tube or other retro numeric display? About $10 will get you one shipped from Russia.
Michael Bean 17th June 2013 01:43 AM
Or how 'bout 3 in a row counting in binary? ;)
All could be on dimly and brighten to show the binary digits that are high, it would be realativly easy to see at a glance.
Mike
M Gregg 17th June 2013 08:39 PM
1 Attachment(s)
As promised..
I quite like this layout as 3mm green LED's in the corner of a chassis..
I'm not a fan of the seven seg display...
The other way I like is with different colours under a glass prism so it changes colour with the input...
M. Gregg
gmphadte 25th June 2013 06:23 AM
Fix one led on the shaft of the switch, at a distance, or an indicating wheel painted red(or choice color) at, as indication, with the optical windows.
Gajanan
Resources saved on this page: MySQL 18.75%
