Construction Tips Construction techniques and tips
Bare Speaker mounted in brick wall
Old 30th May 2013, 03:01 AM   #11
bear is offline bear
expert in tautology
bear's Avatar
with that Fs, it's not exactly a great driver for this application.
also you may find the suspension *may* not be up to handling that much SPL...
I urge you to read the other IB threads here to get some other ideas.
It's fine to go ahead and do this experiment, but I'd blast a hole large enough for at least a standard 12" driver and best, a 15". (we can skip the 18" drivers for now).
Also I don't recall reading what is on the other side of that brick wall?
Is it open to another space or is it a cavity between walls, with studs??
Big difference in what you need to do.
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 4th June 2013, 03:46 PM   #12
AndrewCollett is offline AndrewCollett  South Africa
Default The Finished product
Hey guys, so I went ahead with it, decided to see what would happen. Here's a few pictures, and a few questions at the end.
The driver sounds better, but that's not saying much, since the driver was in the box in the picture, which I put together myself with no calculations, just guess work. The volume is less, which makes sense since there's no port, but tit sounds more "accurate", and just generally a little better. Also, no vibrating at certain frequencies. Which is nice.
Question, what should I use between the wall and the speaker? The part that is screwed down, I have a bit of t shirt in there at the moment. Should I use something like silicone to glue it down? or what?
Once I have completed the cupboard on the other side of the wall, (I need to plaster the wall and build in the cupboard, no backing or siding will be used) I'll see what the speaker sounds like, and decide if I want to do the other, or seal up the hole.
Any other thoughts? advice?
Old 13th June 2013, 07:25 AM   #13
Andersonix is offline Andersonix  Sweden
Andersonix's Avatar
We're afraid to give advice to someone who removes bricks from a load-bearing corner without checking with their parents first.
Old 13th June 2013, 07:54 AM   #14
Um? Yes. It would be a very good thing to be hesitant to not give advice to those people.
However.
My parents do know:P My dad was keen on knowing how it'd work out.
More importantly, the wall is internal, and not load bearing. I checked this in the ceiling. Moreover, its a single brick divider wall, the load bearing walls are two bricks thick on the outer sides. Lol
I'm not that mad
Please do give what advice you guys have that horrible cupboard looking thing with bare walls is now plastered and being painted for a new cupboard to go in.
Old 19th June 2013, 04:01 AM   #15
expert in tautology
bear's Avatar
You need a 100% seal.
I think you may have that... not sure from ur description. the back should be open to the air.
It looks like a smallish driver, and not a sub... so it ought to be pretty ok, but unless you know
the Qt and VAS plus the Xmax its hard to know what it will do in this IB set up...
_-_-
_-_-bear
Bare Speaker mounted in brick wallHide this!Advertise here!
FIR/Brick Wall Crossovers rvrazvan Multi-Way 9 31st December 2013 01:22 PM
Slimline Wall-Mounted Speaker - Aura NS3-193 / Dayton ND20TB-4 johnmark Swap Meet 1 21st May 2012 03:13 PM
Another brick in the wall Supersasha Introductions 6 16th February 2008 07:53 PM
Wall mounted speaker project for LCD TV velmeran42 Multi-Way 2 2nd April 2007 04:19 AM
Posted design for wall-mounted speaker Zaph Multi-Way 1 21st July 2005 09:43 PM
