Linkwitz wm-61a mod preamp PCB, any comments? Linkwitz wm-61a mod preamp PCB, any comments? - diyAudio
Construction Tips Construction techniques and tips
Old 17th May 2013, 09:15 AM   #1
mrkva is offline mrkva  Netherlands
Default Linkwitz wm-61a mod preamp PCB, any comments?
Hey guys,
I have designed a PCB for Linkwitz WM-61a mod preamp.
I went for a design with two gain options (x10 and x100), pseudo balanced output (hence 200ohm resistors). Also, I wanted to make it as-small-as-possible and all DIP based for easy beginners assembly.
Any comments?
Thank you!
Old 8th April 2016, 02:16 PM   #2
kaliwraith is offline kaliwraith
Hey, old thread, but I was searching for this exact thing. Did you ever make pcbs from this or find someone who makes them?
Thanks!
Old 9th April 2016, 11:05 AM   #3
I wonder why he has connected the junction of R1 /R11 to -9V?
Is this a version of phantom powering?
Surely this junction goes to audio ground.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 9th April 2016, 11:26 AM   #4
infinia is offline infinia  United States
infinia's Avatar
no it's correct
(the mic capsule mod, changes the FET inside it to a source follower.)
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 9th April 2016, 11:34 AM   #5
infinia's Avatar
Thanks!
just use perfboard all the originals used perfboard.
perhaps use the PCB layout above for a parts placement/ wiring guide?
Old 9th April 2016, 05:36 PM   #6
Originally Posted by infinia View Post
no it's correct
Thanks.
regards Andrew T.
Linkwitz wm-61a mod preamp PCB, any comments?Hide this!Advertise here!
WM-61a/Linkwitz Mod. PROBLEMS!!!! runbux Parts 13 2nd December 2013 01:49 AM
WM 61a advice for non-measurement use mrkva Parts 11 10th January 2013 12:22 PM
Problem connecting WM-61A to Monacor MPR-1 Preamp Schmeichel1 Equipment & Tools 1 18th April 2011 11:41 PM
linkwitz wm-61a mic + preamp picking up country music station natek83 Construction Tips 10 20th November 2010 01:45 AM
Copyright ©1999-2017 diyAudio
