Construction Tips Construction techniques and tips
Layout question: Bypass capacitor and fuse arrangement
Old 15th May 2013, 09:42 PM   #1
terranigma is offline terranigma
terranigma's Avatar
Default Layout question: Bypass capacitor and fuse arrangement
Hello all,
I'm trying to design a pcb layout for Elvee's Circlophone amplifier. I want to place fuses on PCB and followed by bypass capacitors regarding to the current flowing direction. I want to make sure bypass caps are visible to the circuit so, I draw U shaped traces as shown in layout "A" for ensuring the current flow over the bypass capacitor. I wonder if this principle is practical and advantageous comparing to the "B" one which is same layout in theory but doesn't convince me for real conditions. For the theory, current must be follow the shortest path thus, bypass cap could remain as misled in "B".
What do you think?
Thanks.
Old 16th May 2013, 05:37 AM   #2
gmphadte is offline gmphadte  India
It should be as in A, as B will give you noise/hum and is not correct.
Gajanan Phadte
Old 16th May 2013, 08:06 AM   #3
terranigma's Avatar
Gajanan Phadte
Thank you Gajanan for the comment. I was already on "A" side but I was in need for some confirmation.
The full layout can be seen on link below. Any comment are welcome.
http://www.diyaudio.com/forums/solid...ml#post3490468
Regards.
Old 17th May 2013, 04:01 PM   #4
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
B is better, of course, simply because there's more copper and thus less resistance in general.
Why?
Because that copper "island" which connects Fuse+bypass cap+rest of the circuit is "equipotential" meaning "all its points are at the exact same voltage" meaning "connecting anywhere is the same" meaning all relevant connections (fuse/cap/amp) are the same as if they were twisted together and surrounded in solder.
This kind of weird ideas come from abuse of the "hydraulic analogy" where current flow is explained by imagining it's "water along a tube" which confuses more than it explains, because
a) water has mass ; electricity does not.
b) water has "low" velocity, so it passes by a point "before" it passes another, further away ; electricity has infinite speed and "gets everywhere at the same time"
c) different points of a mass of water can move away from each other or have different speeds ; electricity moves "instantly".
Before somebody nitpicks about speed of light, inductance, etc. , that becomes significant when parts are far away and connected through long and thin wires, not the case here.
Yes, putting that bypass cap 3 feet away, connected with 1mm wire can bring some problems, either at high frequencies where inductance becomes significative, or because wire resistance (specially at the ground return) can start to bother .... but not in a 1" x 1" copper "island", where maximizing copper is best.
Yes, the cap *will* be "visible" to the amp.
Old 18th May 2013, 08:26 AM   #5
Elvee is offline Elvee  Belgium
Elvee's Avatar
A is suitable when the cap is a filter cap, in a conventional supply or SMPS, it will minimize the ripple residues.
But here, the cap's role is as a local bypass, to provide a low impedance return path for the currents from the amplifier, and B should be used
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophoneİ ♫♪
Layout question: Bypass capacitor and fuse arrangementHide this!Advertise here!
Alternative feedback capacitor arrangement steveh49 Solid State 20 8th June 2012 12:51 PM
Bypass capacitor question mtl777 Parts 2 7th August 2010 07:40 PM
Question about cathode bypass capacitor: rockgardenlove Tubes / Valves 4 24th October 2008 08:34 AM
Question about cathode bypass capacitor argo Tubes / Valves 15 20th February 2005 10:26 PM
Question on capacitor arrangement for aleph 2 amp BrianGT Pass Labs 11 12th March 2002 09:51 PM
