Construction Tips Construction techniques and tips
Photoresist etching
Photoresist etching
Old 11th May 2013, 07:34 PM   #1
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Default Photoresist etching
I cant seem to get this to work. No matter how long I expose the boards, when put into the positive developer, it just dissolves away. I am using dual 15W daylight flourescents. Any help appreciated.
Is my transparency not dark enough?
...Shape the sound , Man!
Old 11th May 2013, 08:23 PM   #2
Conrad Hoffman is offline Conrad Hoffman  United States
FWIW, any photoresist I've used takes a lot to fully expose it, and it takes UV. Commercially they use things like mercury arc lamps. What's great for exposing the stuff is really bad for your skin and eyes. Maybe the lamps from an EPROM eraser would work, or some quartz halogens with no protective cover- blocks the UV. Bright sun perhaps?
I may be barking up the wrong tree, but at least I'm barking!
Old 11th May 2013, 08:38 PM   #3
buzzforb's Avatar
Gonna try the sun tomorrow.
Old 11th May 2013, 08:50 PM   #4
dmills is offline dmills  United Kingdom
Yup, UV it must be, visable light just is not energetic enough.
The sun might get there eventually, but for my money proper UV tubes are not that expensive, and will get the job done quick like.
Regards, Dan.
Old 11th May 2013, 09:11 PM   #5
buzzforb's Avatar
PLease give me an example of a proper UV bulb. Seem difficult to find these days.
May try UV LED's. Mouser sells them for $.70/piece at 385nm. Should do the trick nicely and is inexpensive.
Old 11th May 2013, 10:58 PM   #6
EssB is offline EssB  United Kingdom
Hang on, if all your resist dissolves away in the developer then you've over exposed it. At least that's the way the stuff I use works - exposed parts dissolve away and then get etched away, non exposed parts ... leave copper.
Have you tried doing a test strip ?
FWIW I use 2 mins UV exposure in a fairly 'bright' UV box.
Old 12th May 2013, 04:13 AM   #7
counter culture is offline counter culture  United States
I have about 100 UV LEDs in a 12*10 inch array. Throw is about 12 inches. Exposure time is ~6 minutes using inkjet transparencies.
Now I am Become Death, the Destroyer of Words
Old 12th May 2013, 05:09 AM   #8
surface tension is offline surface tension  United States
surface tension's Avatar
If you are using MG Chemicals presensitized boards (from Fry's) about 30 seconds under bright midday sun with a piece of glass usually works. The image on the transparency film needs to be dark. I take my artwork to the local reprographics shop and print black only on a Canon color laser copier ($2-3 for an 8.5x11) and spot with a black Sharpie to cover any pinholes. Keep trying!
Old 13th May 2013, 12:04 AM   #9
dangus is offline dangus  Canada
Photoresist etching
Another vote for doing a test strip. It's the only way to be sure.
With inkjet or laser-printed artwork, I use two layers so it's completely opaque.
I've never used sunlight to expose boards; I started with a photoflood intended for home movies, then used incandescent tanning bulbs, and finally got a pair of fluorescent tubes, probably F15T8/BL.
Old 13th May 2013, 12:52 AM   #10
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
I gave up on home grown pcb's and buy in low quantities from China.
I get back very professional looking pcb's at a very low price.
Its usually about 55 for 5 medium sized pcb's.
With 2 week turnaround.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Photoresist etchingHide this!Advertise here!
Toner transfer or photoresist for SMD precision PCB JanErik Construction Tips 9 18th September 2012 10:15 AM
photoresist Stefanoo Parts 21 30th April 2012 07:23 PM
Spray on Photoresist- How Successful is it. Mooly Parts 27 3rd August 2008 10:18 AM
Photoresist shivela39 Parts 3 26th March 2006 04:45 AM
wipe / rub on photoresist? bigpanda Everything Else 6 29th September 2005 10:27 AM
