Construction Tips Construction techniques and tips
Fixing transistor on heatsink
Old 11th May 2013, 08:09 AM   #1
Project16 is offline Project16  France
Project16's Avatar
Default Fixing transistor on heatsink
Hello everyone!
I'll try to explain my problem clearly.
To fix my printed transistors on the heat sink power circuit I need to insert an aluminum plate 6 mm thick but I find only 3 mm plate.
My question is simple:
If I put two plates of thickness 3 minutes between my transistors and the heat sink, it will be effective equivalent to a single sheet of 6 mm.
I made a little drawing.
Regards!
Old 11th May 2013, 08:13 AM   #2
Mooly's Avatar
In practice there probably isn't any issue whatsoever, particularly if you use thermal paste on all surfaces.
Old 11th May 2013, 08:22 AM   #3
Project16's Avatar
Mooly thank you for your reply but I use an online translator and the response is inconsistent.
If I understand here is no problem but you have to put the thermal paste between all surfaces.
Regards!
Old 11th May 2013, 08:22 AM   #4
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
The mating surfaces will need to be flat and shiny and coated with a thin coating of thermal paste.
Old 11th May 2013, 08:48 AM   #5
Project16's Avatar
Mooly and KatieandDad, thank you!
Old 11th May 2013, 09:38 AM   #6
R.I.P.
you will need a lot of bolts to ensure the gaps between the plates and the sink are small all over the whole plate area.
A grid of bolts @ 30mm vertically and 30mm horizontally?
regards Andrew T.
Old 11th May 2013, 10:08 AM   #7
Project16's Avatar
I thought the whole set on the main as indicated by the hole transistors (red points) heatsink.
The aluminum plate is barely wider than the Sanken.
Regards!
Old 11th May 2013, 10:17 AM   #8
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
imho, you are better off with just a 3mm plate....any reason it had to be 6mm?
with just a 3mm plate you have 1 less thermal junction to worry about...you can always bend the trannie legs a bit....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 11th May 2013, 10:24 AM   #9
Elvee is online now Elvee  Belgium
Elvee's Avatar
Which is preferable anyway to relieve the stress caused by straight legs.
Translation to avoid project16 the inconvenience of using a translator:
Il est préférable de plier les pattes des transistors pour éviter les contraintes causées par un montage droit
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 11th May 2013, 10:36 AM   #10
Project16's Avatar
This is to avoid bending the legs of the transistors.
But I can (by bending the legs of Sanken) fix directemment on the main heatsink but I have to add an aluminum thickness for BD139 and 140 because the legs are too short.
Why 6 mm:
Is the distance between the base of one and the edge of Sanken PCB.
Fixing transistor on heatsinkHide this!Advertise here!
transistor mounting technique ? Heatsink guitar89 Solid State 4 17th September 2011 12:26 PM
transistor placement on a heatsink Mattyo5 Solid State 23 5th May 2003 09:25 AM
Help - Mounting transistor to heatsink vsr123 Pass Labs 10 17th April 2003 11:43 AM
Fixing old gear / Transistor problems OliverD Parts 1 8th February 2003 10:06 PM
Vertical positioning of transistor on heatsink Eric Pass Labs 2 4th December 2002 03:14 PM
